I just casually submitted an application
I was hoping it would work.
The management here looks extremely strict.
Sure, but it looks like you need to apply using your real name.
I seem to remember hearing that applications used to be pretty strict—you had to provide your real name and write a short essay. But the site owner uses it too, so it’s understandable.
But couldn’t you just make up any name?
Yes, a long time ago.
Sure.
My site: clina.zz.ac
Is this domain on the PSL?
Acting like it can’t be used without them
gmda
Okay, I also applied for one under my real name.
Actually, there’s no need to use your real name (it’s not like they can force you to take a photo of your ID card. Just make up a fake name, and that’ll do.
Where can I apply?
I’ve never owned one, so I don’t know whether I can use it.
It feels pointless to make the requirements for absence so strict.
Which country’s domain is this?
The application was rejected—it doesn’t look good, honestly.
Try it and you’ll know.
It’s not easy to deal with.
