DeepSeek / Kimi official-site queues overloaded: When WorkBuddy and Qoder were just as stuck, I switched Flash to my own compute route
It looks like ds still isn’t working.
It was packed around 5 p.m.
I don’t know why
My reverse proxy for CodeBuddy is also lagging like crazy.
Roughly how low can the time to first token be brought down during peak hours on a dedicated compute line?
Turns out DeepSeek was down—I thought the problem was on my end.
It’s quite common for the official DeepSeek site / upstreams sharing the same origin to get overloaded during peak periods; if a reverse proxy ultimately hits the same pool, it may feel slow too, so the client itself isn’t necessarily at fault.
With our own compute, there’s no guaranteed TTFT during peak periods, as it depends on the entry point, concurrency, and context. When I tested with deepseek-flash, the time to the first token was usually noticeably more stable than the official site’s queue pool, but I still recommend running several rounds locally using the same curl command / client logs and checking the P50. During testing, set model to the public ID deepseek-flash, use an OpenAI-compatible base_url ending in /v1, and don’t enter the display name shown on the page.
If the screenshot shows that DeepSeek on the official site isn’t working, or you’re unsure whether it’s getting stuck on the first token or halfway through, sharing the error JSON / response headers (with the key redacted) would make troubleshooting easier.
