We insist on transparent operations, with a multilayer Pelican testing system deployed across the entire site to strictly control model quality and eliminate degraded accounts. All performance metrics are publicly verifiable, and everyone is welcome to conduct their own tests and expose any issues.
Quality Assurance: Multilayer Inspections, Automatic Cooldowns for Degraded Accounts
- High-frequency inspections: a rapid check every 5 minutes + a complete Pelican benchmark test every hour, running continuously 24/7 to monitor the models’ reasoning capabilities in real time
- Intelligent risk control: accounts detected as degraded are automatically put into cooldown, preventing silent degradation at the system level and ensuring stable output quality
- Dedicated stability: the DeepSeek route is specially monitored around the clock to consistently maintain full performance
Full-Chain Transparency: Verifiable Data, No Empty Promises
- Test records are retained throughout the process. The side-panel monitoring dashboard allows you to check the live operating status at any time, with historical results fully traceable
- Real-time visualization of the cache backend: cache hits for every request and the overall cache hit rate are clearly available, with transparent and public billing rules
- Test results are synchronized to the QQ group 24/7, so you can keep track of status updates at any time
Pricing Advantage: Transparent Low-Multiplier Billing
- GPT from as low as 0.05×
- DeepSeek from as low as 0.04×
- Image-generation models from as low as 0.01×
- Caching works normally online and is billed according to the rules—save money and know exactly what you’re paying for
Stable Access: Nodes Monitored Around the Clock
24/7 node response monitoring, with latency and failure rates kept strictly under control to ensure smooth, reliable API calls and reduce lag and timeouts.
Models are delivered as advertised, with no dilution in quality. You’re welcome to run Pelican tests yourself and pull samples for comprehensive verification. If you have any questions, feel free to get in touch.
Address: xinyue.mom
xinyue.mom GPT-5.5 Test Report|MODELOC
The report was posted according to the rules; it does not reflect the current status.
