rt, two old accounts that hadn’t been used in a long time: one was disabled, while I can’t log into the other, and it’s on the verge of being banned.
They were mainly used to register accounts and receive emails. The one that got banned had been set up a long time ago with email forwarding, a dedicated password for POP/IMAP, and spam filtering disabled—in other words, it could receive emails without needing a special environment. Then I stupidly logged in and it got banned. My appeals were rejected three times, so I guess there’s no hope.
The other one also had email forwarding set up, but I discovered that I hadn’t clicked the confirmation link. ![]()
What a shame about those two six-character Gmail addresses. I still don’t know what to do about all the websites registered with them.
I didn’t notice it.
I’d also really like to know why Google bans accounts.
If Google bans an account, what did they probably do?
New accounts may have certain environment requirements. As for old accounts, unless you happen to hit the boundary, it’s generally very hard for them to ban you. ![]()
Could it be because I hadn’t logged in for too long, and logging in suddenly triggered it?
New accounts are subject to strict security checks. Older accounts should generally be fine as long as you don’t switch devices too often, but it’s best to use a phone number that can be verified.
A very clean environment is needed.
Mine was banned too, and I can’t get it back even after appealing.
My condolences.
The IP is bad.
I recommend keeping the full Google suite signed in on your phone all the time; that makes your account less likely to get banned. Google even bans dormant accounts.
I’ve never been banned.
What mischief have you been up to? Come on, tell me!
What is a zombie account?
Accounts that have been inactive for a long time
How is “active” determined?
It seems that your account will be deleted if you don’t log in for two years.
Just use a stable overseas IP. It generally won’t get blocked. Overseas servers from providers like LuckVM and Liangxin Cloud work fine; Hong Kong is best because it’s relatively fast.
Use Google AI more often, or use an account to watch YouTube.
