Cloudflare system load exceeds a certain value: automatically switch 5-second shield script
Cloudflare system load exceeds a certain value automatically switches to 5-second shield script.
When your server is under a CC attack, the system load will spike. At this time, you can use this script to automatically detect the system load. When the pressure exceeds a certain value, it will switch to the "I'm Under Attack!" mode.
### Official Address
https://github.com/Machou/Cloudflare-Block
### Download Script
First, download the script from the official website or from this site:
`wget https://dl.yunloc.com/Shell/cloudflare-block.sh && chmod +x cloudflare-block.sh`
*cloudflare-block.sh script:
`#!/bin/bash
$1 = 1min, $2 = 5min, $3 = 15min
loadavg=$(awk ‘{printf “%f”, $1}’ < /proc/loadavg)
load is 10, you can modify this if you want load more than 10
maxload=10
Configuration API Cloudflare
Your Global API Key (https://dash.cloudflare.com/profile)
api_key=
Email of your Cloudflare account
email=
Zone ID (https://dash.cloudflare.com/_zone-id_/domain.com)
zone_id=
Default security level when there is no attack, see in readme
default_security_level=high
Whether to write debug messages to the debug.log file under script dir
debug=0
basedir=$(dirname “$0”)
attacked_file=$basedir/attacked
[ “debug" -eq 1 ] && exec > "{logfile:-$basedir/debug.log}”
You can put aforementioned config values either in-place
or in the file named ‘config’ in the script’s directory.
config_file=$basedir/config
[ -e “$config_file” ] && source “$config_file”
api_set_mode() {
local mode
mode=$1
curl -s -X PATCH “https://api.cloudflare.com/client/v4/zones/$zone_id/settings/security_level
-H “X-Auth-Email: $email”
-H “X-Auth-Key: $api_key”
-H “Content-Type: application/json”
–data “{"value":"$mode"}”
|| echo “Error: failed to set security level to $mode”
create file “attacked” if doesn’t exist
if [ ! -e “$attacked_file” ]; then
echo 0 > “$attacked_file”
fi
was_under_attack=$(cat "attacked_file") under_attack=(echo “$loadavg > $maxload” | bc)
if [[ “$1” != [01] ]]; then
echo “Incorrect usage! Please pass either 0 or 1 as an argument”
exit 1
fi
if [ $debug -eq 1 ]; then
echo “Mode: $1; was under attack: $was_under_attack; now under attack: $under_attack”
echo “Load average: $loadavg”
fi
if [ “$1” -eq 0 ] && [ “$was_under_attack” -eq 0 ] && [ “$under_attack” -eq 1 ]; then
attack just started and we want to enable under-attack mode
Activate protection
[ “$debug” -eq 1 ] && echo “Activating under-attack mode!”
echo 1 > “$attacked_file”
api_set_mode under_attack
elif [ “$1” -eq 1 ] && [ “$was_under_attack” -eq 1 ] && [ “$under_attack” -eq 0 ]; then
attack just finished (and up to 20 minutes passed since)
and we want to disable under-attack mode
Disable Protection
[ “$debug” -eq 1 ] && echo “Leaving under-attack mode!”
api_set_mode “$default_security_level”
fi
exit 0
Modify cloudflare-block.sh configuration:
`# # Your cloudflare API key (https://dash.cloudflare.com/profile) API_KEY= # Your Cloudflare account email email= # Zone ID (https://dash.cloudflare.com/_zone-id_/domain.com) zone_id= # Default security level when there is no attack, see in readme default_security_level=high # Whether to write debug messages to the debug.log file under script dir debug=0`
The script defaults to detecting a system load of 10 and starting the "I'm Under Attack!" mode. You can adjust this according to your needs, generally setting it to your core count * 1.2, for example, if your CPU is dual-core, you can set it to 2.4.
`maxload= 7`
Set cron jobs: check every minute if protection is not enabled, and turn on the 5-second shield if the load is above 7. Check every 20 minutes if protection is enabled, and turn off the 5-second shield if the load drops below 7:
`*1 * * * * /root/cloudflare-block.sh 0 */20 * * * * /root/cloudflare-block.sh 1`
### Summary
Cloudflare is a very useful tool for defending against DDoS and CC attacks. The free version of Cloudflare combined with API can achieve more flexible functions, which are sufficient for ordinary defense.
已经习惯来回切换IP:huaji09:
昨天是不是还加了一个旋转图片验证,之前没碰到过
@“[未知用户]”#p14443 是的,加了一个waf的验证,这是面向国内的服务器,没有套CF,所以加一个waf验证。
那也就是现在被攻击了?
之前 @“[已注销]”#1215 说没有用啊
@“削除禁止”#p14672
有比没有强,我说的是不能过分依赖这种办法,并不是说这个一点用没有
自动开盾,防的住低阶攻击,防不住高阶攻击
