n/review · 2024-07-02 · 488 次浏览
u/everett7623王者
n/reviewu/everett7623 · 2024-07-02
Niihost HONGKONG-BGP - BASIC-ANNUAL $24/y 简测
Niihost,新商家,纯入手体验,稳定性有待考察。
## Niihost商家介绍
Niihost,新商家,有香港,日本,新加坡机房。
## Niihost 官网直达
~~~~https://www.niihost.com/
## Niihost 测试机器 配置如下
### HONGKONG-BGP - BASIC-ANNUAL
| Item | Configurations |
| CPU | 1 Core |
| Memory | 1 GB |
| Disk Space | 15 GB |
| Bandwidth | [email protected] |
| Operating System | Debian 11 |
| IPv4 Address | 1 |
| IPv6 Address | 0 |
| Location | HongKong |
| Route | BGP Session |
| Price | $24.00 USD |
| Billing Cycle | Annually |
~~~~产品直达链接 AFF
### 后台截图
Niihost Hongkong-BGP-BAIC-ANNUAL 1.png~~
## 测试环境
宽带:上海联通 200M
时间:20240701
协议:勇哥4合1的vless(一些测试待补充)
## 简评
这台Niihost HONGKONG-BGP - BASIC-ANNUAL 香港24刀小鸡,年付5折,3年付3折,力度有点吓人,新商家还是需要谨慎。。
解锁不错。三网的话电信不给力,移动和联通看起来还可以。
[tabs]
[tab="YABS"]
Yet-Another-Bench-Script
v2024-06-09
https://github.com/masonr/yet-another-bench-script
Mon Jul 1 14:55:01 UTC 2024
Basic System Information:
Uptime : 0 days, 7 hours, 30 minutes
Processor : Common KVM processor
CPU cores : 1 @ 2299.996 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 942.8 MiB
Swap : 0.0 KiB
Disk : 14.7 GiB
Distro : Debian GNU/Linux 11 (bullseye)
Kernel : 5.10.0-29-amd64
VM Type : KVM
IPv4/IPv6 : ✔ Online / ✔ Online
IPv6 Network Information:
ISP : Eons Data Communications Limited
ASN : AS138997 Eons Data Communications Limited
Host : Eons Data Communications Limited
Country : Hong Kong
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1):
Read | 44.65 MB/s (11.1k) | 419.16 MB/s (6.5k)
Write | 44.71 MB/s (11.1k) | 421.37 MB/s (6.5k)
Total | 89.37 MB/s (22.3k) | 840.54 MB/s (13.1k)
Read | 766.55 MB/s (1.4k) | 861.81 MB/s (841)
Write | 807.28 MB/s (1.5k) | 919.20 MB/s (897)
Total | 1.57 GB/s (3.0k) | 1.78 GB/s (1.7k)
iperf3 Network Speed Tests (IPv4):
Provider Location (Link) Send Speed Recv Speed Ping
Clouvider London, UK (10G) 44.3 Mbits/sec 527 Mbits/sec 187 ms
Eranium Amsterdam, NL (100G) busy busy --
Uztelecom Tashkent, UZ (10G) busy 146 Mbits/sec 303 ms
Leaseweb Singapore, SG (10G) 844 Mbits/sec 2.78 Gbits/sec --
Clouvider Los Angeles, CA, US (10G) 40.1 Mbits/sec 572 Mbits/sec 165 ms
Leaseweb NYC, NY, US (10G) 362 Mbits/sec 763 Mbits/sec 212 ms
Edgoo Sao Paulo, BR (1G) busy 9.81 Mbits/sec 295 ms
iperf3 Network Speed Tests (IPv6):
Clouvider London, UK (10G) 504 Mbits/sec 908 Mbits/sec 187 ms
Uztelecom Tashkent, UZ (10G) busy busy 302 ms
Leaseweb Singapore, SG (10G) 717 Mbits/sec 2.17 Gbits/sec 30.8 ms
Clouvider Los Angeles, CA, US (10G) 631 Mbits/sec busy 165 ms
Leaseweb NYC, NY, US (10G) 321 Mbits/sec 808 Mbits/sec --
Edgoo Sao Paulo, BR (1G) busy 457 Mbits/sec 295 ms
Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
YABS completed in 17 min 23 sec
[/tab]
[tab="融合怪"]
版本:2024.06.24
更新日志:VPS融合怪测试(集百家之长)
---------------------基础信息查询--感谢所有开源项目---------------------
CPU 型号          : Common KVM processor
CPU 核心数        : 1
CPU 频率          : 2299.996 MHz
CPU 缓存          : L1: 64.00 KB / L2: 4.00 MB / L3: 16.00 MB
AES-NI指令集      : ✔ Enabled
VM-x/AMD-V支持    : ❌ Disabled
内存              : 157.15 MiB / 942.80 MiB
Swap              : [ no swap partition or swap file detected ]
硬盘空间          : 1.49 GiB / 14.60 GiB
启动盘路径        : /dev/sda1
系统在线时间      : 0 days, 7 hour 57 min
负载              : 0.11, 0.16, 0.23
系统              : Debian GNU/Linux 11 (bullseye) (x86_64)
架构              : x86_64 (64 Bit)
内核              : 5.10.0-29-amd64
TCP加速方式       : cubic
虚拟化架构        : KVM
NAT类型           : Full Cone
IPV4 ASN          : AS138997 Eons Data Communications Limited
IPV4 位置         : Kwai Chung / Kwai Tsing / HK
IPV6 ASN          : AS138997 Eons Data Communications
IPV6 位置         : Ha Kwai Chung / Kwai Tsing / Hong Kong
IPV6 子网掩码     : 128
----------------------CPU测试--通过sysbench测试-------------------------
1 线程测试(单核)得分:          689 Scores
2 线程测试(多核)得分:          697 Scores
---------------------内存测试--感谢lemonbench开源-----------------------
单线程读测试:          13997.31 MB/s
单线程写测试:          10135.12 MB/s
------------------磁盘dd读写测试--感谢lemonbench开源--------------------
测试操作               写速度                                  读速度
100MB-4K Block         34.2 MB/s (8338 IOPS, 3.07s)            46.2 MB/s (11288 IOPS, 2.27s)
1GB-1M Block           889 MB/s (848 IOPS, 1.18s)              1.1 GB/s (1048 IOPS, 0.95s)
---------------------磁盘fio读写测试--感谢yabs开源----------------------
Read       | 47.36 MB/s   (11.8k) | 425.65 MB/s   (6.6k)
Write      | 47.42 MB/s   (11.8k) | 427.89 MB/s   (6.6k)
Total      | 94.78 MB/s   (23.6k) | 853.54 MB/s  (13.3k)
Read       | 774.69 MB/s   (1.5k) | 803.15 MB/s    (784)
Write      | 815.86 MB/s   (1.5k) | 856.64 MB/s    (836)
Total      | 1.59 GB/s     (3.1k) | 1.65 GB/s     (1.6k)
------------流媒体解锁--基于oneclickvirt/CommonMediaTests开源-----------
[IPV4]
您的出口IP完整解锁Netflix,支持非自制剧的观看
NF所识别的IP地域信息:中国香港
[IPV6]
NF所识别的IP地域信息:中国香港
[IPV4]
连接方式: Youtube Video Server
视频缓存节点地域: 中国香港(HKG33S01)
Youtube识别地域: 中国香港(HK)
[IPV6]
视频缓存节点地域: 中国香港(HKG07S42)
[IPV4]
当前出口所在地区解锁DisneyPlus
区域:HK 区
[IPV6]
区域:HK 区
----------------流媒体解锁--感谢RegionRestrictionCheck开源--------------
以下为IPV4网络测试,若无IPV4网络则无输出
以下为IPV6网络测试,若无IPV6网络则无输出
Dazn:                                  IPv6 Is Not Currently Supported
Disney+:                               IPv6 Is Not Currently Supported
Netflix:                               Yes (Region: HK)
YouTube Premium:                       Yes (Region: HK)
Amazon Prime Video:                    IPv6 Is Not Currently Supported
TVBAnywhere+:                          IPv6 Is Not Currently Supported
Spotify Registration:                  No
Instagram Licensed Audio:              No
OneTrust Region:                       HK [Kwai Tsing]
iQyi Oversea Region:                   IPv6 Is Not Currently Supported
Bing Region:                           HK
YouTube CDN:                           Hong Kong
Netflix Preferred CDN:                 Hong Kong
ChatGPT:                               Failed (Network Connection)
Wikipedia Editability:                 No
Google Search CAPTCHA Free:            Yes
Steam Currency:                        IPv6 Is Not Currently Supported
---Forum---
Reddit:                                IPv6 Is Not Currently Supported
---------------TikTok解锁--感谢lmc999的源脚本及fscarmen PR--------------
Tiktok Region:         Failed
-------------IP质量检测--基于oneclickvirt/securityCheck使用-------------
以下为各数据库编号,输出结果后将自带数据库来源对应的编号
ipinfo数据库  [0] | scamalytics数据库 [1] | virustotal数据库   [2] | abuseipdb数据库   [3] | ip2location数据库    [4]
ip-api数据库  [5] | ipwhois数据库     [6] | ipregistry数据库   [7] | ipdata数据库      [8] | db-ip数据库          [9]
ipapiis数据库 [A] | ipapicom数据库    [B] | bigdatacloud数据库 [C] | cheervision数据库 [D] | ipqualityscore数据库 [E]
IPV4:
安全得分:
声誉(越高越好): 0 [2]
信任得分(越高越好): 37 [8]
VPN得分(越低越好): 0 [8]
代理得分(越低越好): 100 [8]
社区投票-无害: 0 [2]
社区投票-恶意: 0 [2]
威胁得分(越低越好): 89 [8]
欺诈得分(越低越好): 65 [E] 50 [1]
滥用得分(越低越好): 0 [3]
ASN滥用得分(越低越好): 0.0008 (Low) [A]
公司滥用得分(越低越好): 0.0017 (Low) [A]
威胁级别: low [B]
黑名单记录统计:(有多少黑名单网站有记录):
无害记录数: 0 [2]  恶意记录数: 0 [2]  可疑记录数: 0 [2]  无记录数: 93 [2]
安全信息:
使用类型: hosting [0 7 A] DataCenter/WebHosting/Transit [3] business [8] unknown [C]
公司类型: hosting [A] business [0] isp [7]
是否云提供商: Yes [7 D]
是否数据中心: No [0 5 6 8 C] Yes [1 A]
是否移动设备: Yes [E] No [5 A C]
是否代理: Yes [E] No [0 1 4 5 6 7 8 A B C D]
是否VPN: Yes [E] No [0 1 6 7 A C D]
是否Tor: No [0 1 3 6 7 8 A B C D E]
是否Tor出口: No [1 7 D]
是否网络爬虫: No [A B E]
是否匿名: No [1 6 7 8 D]
是否攻击者: No [7 8 D]
是否滥用者: No [7 8 A C D E]
是否威胁: No [7 8 C D]
是否中继: No [0 7 8 C D]
是否Bogon: No [7 8 A C D]
是否机器人: No [E]
DNS-黑名单: 311(Total_Check) 0(Clean) 9(Blacklisted) 13(Other)
IPV6:
安全得分:
欺诈得分(越低越好): 0 [1]
滥用得分(越低越好): 0 [3]
威胁级别: low [B]
安全信息:
使用类型: hosting [A] DataCenter/WebHosting/Transit [3]
公司类型: hosting [A]
是否云提供商: Yes [D]
是否数据中心: Yes [1 A]
是否移动设备: No [A]
是否代理: No [1 A B D]
是否VPN: No [1 A D]
是否TorExit: No [1 D]
是否Tor出口: No [1 D]
是否网络爬虫: No [A B]
是否匿名: No [1 D]
是否攻击者: No [D]
是否滥用者: No [A D]
是否威胁: No [D]
是否中继: No [D]
是否Bogon: No [A D]
DNS-黑名单: 311(Total_Check) 0(Clean) 0(Blacklisted) 311(Other)
Google搜索可行性:YES
-------------邮件端口检测--基于oneclickvirt/portchecker开源-------------
Platform  SMTP  SMTPS POP3  POP3S IMAP  IMAPS
LocalPort ✔     ✔     ✔     ✔     ✔     ✔
QQ        ✔     ✔     ✔     ✘     ✔     ✘
163       ✔     ✔     ✔     ✘     ✔     ✘
Sohu      ✔     ✔     ✔     ✘     ✔     ✘
Yandex    ✔     ✔     ✔     ✘     ✔     ✘
Gmail     ✔     ✔     ✘     ✘     ✘     ✘
Outlook   ✔     ✘     ✔     ✘     ✔     ✘
Office365 ✔     ✘     ✔     ✘     ✔     ✘
Yahoo     ✔     ✔     ✘     ✘     ✘     ✘
MailCOM   ✔     ✔     ✔     ✘     ✔     ✘
MailRU    ✔     ✔     ✘     ✘     ✔     ✘
AOL       ✔     ✔     ✘     ✘     ✘     ✘
GMX       ✔     ✘     ✔     ✘     ✔     ✘
Sina      ✔     ✘     ✔     ✘     ✔     ✘
----------------三网回程--基于oneclickvirt/backtrace开源----------------
北京电信 219.141.140.10  检测不到回程路由节点的IP地址
北京联通 202.106.195.68  检测不到回程路由节点的IP地址
北京移动 221.179.155.161 移动CMI    [普通线路]
上海电信 202.96.209.133  检测不到回程路由节点的IP地址
上海联通 210.22.97.1     检测不到回程路由节点的IP地址
上海移动 211.136.112.200 检测不到回程路由节点的IP地址
广州电信 58.60.188.222   电信163    [普通线路]
广州联通 210.21.196.6    检测不到回程路由节点的IP地址
广州移动 120.196.165.24  移动CMI    [普通线路]
成都电信 61.139.2.69     电信163    [普通线路]
成都联通 119.6.6.6       检测不到回程路由节点的IP地址
成都移动 211.137.96.205  移动CMI    [普通线路]
准确线路自行查看详细路由,本测试结果仅作参考
---------------------回程路由--感谢fscarmen开源及PR---------------------
广州电信 58.60.188.222
0.90 ms  AS138997  中国, 香港, cogentco.com
0.74 ms  AS138997  中国, 香港, eons.cloud
2.12 ms  AS138997  中国, 香港, eons.cloud
0.25 ms  AS138997  中国, 香港, eons.cloud
0.99 ms  AS138997  中国, 香港, eons.cloud
0.94 ms  AS138997  中国, 香港, eons.cloud
1.12 ms  AS138997  中国, 香港, eons.cloud
2.01 ms  AS3356  中国, 香港, level3.com
235.04 ms  AS3356  美国, 加利福尼亚州, 圣何塞, level3.com
374.74 ms  AS4134  中国, 广东, 广州, chinatelecom.com.cn, 电信
341.91 ms  AS4134  中国, 广东, 广州, chinatelecom.com.cn, 电信
439.62 ms  AS4134  中国, 广东, 深圳, chinatelecom.com.cn, 电信
广州联通 210.21.196.6
0.35 ms  AS138997  中国, 香港, cogentco.com
0.89 ms  AS138997  中国, 香港, eons.cloud
3.41 ms  AS138997  中国, 香港, eons.cloud
0.33 ms  AS138997  中国, 香港, eons.cloud
2.15 ms  AS138997  中国, 香港, eons.cloud
0.53 ms  AS138997  中国, 香港, eons.cloud
47.90 ms  AS138997  中国, 香港, eons.cloud
47.97 ms  AS7578  中国, 香港, cogentco.com
47.87 ms  AS137409  中国, 香港, cogentco.com
48.05 ms  AS7578  COGENTCO.COM 骨干网, cogentco.com
47.89 ms  AS7578  COGENTCO.COM 骨干网, cogentco.com
47.92 ms  AS7578  日本, 东京都, 东京, cogentco.com
47.88 ms  AS7578  日本, 东京都, 东京, cogentco.com
47.85 ms  AS7578  日本, 东京都, 东京, cogentco.com
180.51 ms  AS4837  中国, 北京, chinaunicom.com, 联通
190.08 ms  AS17623  中国, 广东, 深圳, chinaunicom.com, 联通
156.00 ms  AS17623  中国, 广东, 深圳, chinaunicom.com, 联通
广州移动 120.196.165.24
0.27 ms  AS138997  中国, 香港, cogentco.com
0.71 ms  AS138997  中国, 香港, eons.cloud
1.79 ms  AS138997  中国, 香港, eons.cloud
0.54 ms  AS138997  中国, 香港, eons.cloud
2.93 ms  AS138997  中国, 香港, eons.cloud
0.26 ms  AS138997  中国, 香港, eons.cloud
0.76 ms  *  中国, 香港, nube.sh
34.67 ms  AS58453  新加坡, chinamobile.com, 移动
40.75 ms  AS58453  中国, 香港, chinamobile.com, 移动
94.93 ms  AS58453  中国, 广东, 广州, chinamobile.com, 移动
41.60 ms  AS9808  中国, 广东, 广州, chinamobile.com, 移动
91.18 ms  AS9808  中国, 广东, 广州, chinamobile.com, 移动
46.63 ms  AS9808  中国, 广东, 广州, chinamobile.com, 移动
45.39 ms  AS9808  中国, 广东, 广州, chinamobile.com, 移动
46.67 ms  AS56040  中国, 广东, 深圳, chinamobile.com, 移动
--------------------自动更新测速节点列表--本脚本原创--------------------
位置             上传速度        下载速度        延迟     丢包率
Speedtest.net    4.09 Mbps       3.86 Mbps       1.61     0.0%
中国香港         4052.49 Mbps    1561.53 Mbps    2.41     0.0%
新加坡           509.54 Mbps     405.70 Mbps     38.56    0.0%
联通WuXi         626.16 Mbps     605.30 Mbps     86.25    0.0%
电信浙江         2.43 Mbps       380.68 Mbps     401.52   NULL
电信Suzhou5G     8.86 Mbps       1821.92 Mbps    395.46   NULL
总共花费      : 7 分 49 秒
时间          : Mon Jul  1 15:29:12 UTC 2024
短链:
https://paste.spiritlhl.net/u/1ZUOPz.txt
[/tab]
[tab="IP质量"]
IP质量体检报告:38.181..
bash <(curl -sL IP.Check.Place)
报告时间:2024-07-01 23:31:57 CST 脚本版本:v2024-06-27
一、基础信息(Maxmind 数据库)
自治系统号: AS138997
组织: Eons Data Communications Limited
坐标: 114°8′3″E, 22°21′14″N
地图: https://check.place/22.3539,114.1342,15,cn
城市: Kwai Tsing, 下葵涌
使用地: [HK]香港, [AS]亚洲
注册地: [US]美国
时区: Asia/Hong_Kong
IP类型: 广播IP
二、IP类型属性
使用类型: 机房 机房 机房 机房 机房
公司类型: 商业 机房 机房
三、风险评分
风险等级: 极低 低 中等 高 极高
SCAMALYTICS: 50|高风险
ipapi: 0.17%|低风险
AbuseIPDB: 0|低风险
IPQS: 75|可疑IP
DB-IP: |低风险
四、风险因子
地区: [HK] [HK] [HK] [HK] [HK] [HK] [HK] [HK]
代理: 否 否 否 是 否 否 否 否
Tor: 否 否 否 否 否 否 否 否
VPN: 否 否 否 是 否 无 否 否
服务器: 是 是 是 无 否 否 否 否
滥用: 否 否 否 否 无 否 无 无
机器人: 否 否 无 否 否 无 无 无
五、流媒体及AI服务解锁检测
状态: 失败 解锁 解锁 解锁 解锁 屏蔽 仅APP
方式: 原生 原生 原生 原生 原生
六、邮局连通性及黑名单检测
本地25端口:阻断
IP地址黑名单数据库: 有效 439 正常 432 已标记 5 黑名单 2
今日IP检测量:573;总检测量:36940。感谢使用xy系列脚本!
报告链接:https://Report.Check.Place/IP/65HDIXNQ9.svg
IP质量体检报告:2404:c140:1f00:::::*
一、基础信息(Maxmind 数据库)
自治系统号: AS138997
城市: Kwai Tsing, 下葵涌
使用地: [HK]香港, [AS]亚洲
注册地: [HK]香港
时区: Asia/Hong_Kong
IP类型: 原生IP
二、IP类型属性
公司类型: 机房 机房 机房
三、风险评分
风险等级: 极低 低 中等 高 极高
SCAMALYTICS: 0|低风险
ipapi: 0.00%|极低风险
AbuseIPDB: 0|低风险
IPQS: 38|低风险
四、风险因子
代理: 否 否 否 否 否 否 否 否
VPN: 否 否 否 否 否 无 否 否
服务器: 是 是 是 无 否 否 是 否
滥用: 否 否 否 否 无 否 无 无
五、流媒体及AI服务解锁检测
状态: 失败 解锁 解锁 解锁 屏蔽 屏蔽 失败
地区: [HK] [HK] [HK]
方式: 原生 原生 原生
六、邮局连通性及黑名单检测
本地25端口:阻断
今日IP检测量:574;总检测量:36941。感谢使用xy系列脚本!
报告链接:https://Report.Check.Place/IP/2QY7INWF6.svg
[/tab]
[tab="流媒体"]
[流媒体平台及游戏区域限制测试]
项目地址 https://github.com/lmc999/RegionRestrictionCheck
改版地址 https://github.com/xykt/RegionRestrictionCheck
** 测试时间: Mon Jul 1 15:38:41 UTC 2024
** 正在测试IPv4解锁情况
** 您的网络为: Eons Data Communications (38.181..)
Dazn: 原生解锁 Yes (Region: HK)
TikTok: Failed
Disney+: 原生解锁 Yes (Region: HK)
Netflix: 原生解锁 Yes (Region: HK)
YouTube Premium: 原生解锁 Yes (Region: HK)
Amazon Prime Video: 原生解锁 Yes (Region: HK)
TVBAnywhere+: No
iQyi Oversea Region: 原生解锁 HK
Steam Currency: HKD
ChatGPT: 原生解锁 APP Only (Region: HK)
Bing Region: HK
---Forum---
Reddit: Yes
=============[ Hong Kong ]=============
Now E: Yes
Viu.com: 原生解锁 Yes (Region: HK)
Viu.TV: Yes
MyTVSuper: No
HBO GO Asia: Yes (Region: HK)
BiliBili Hongkong/Macau/Taiwan: Yes
** 正在测试IPv6解锁情况
** 您的网络为: Eons Data Communications (2404:c140:1f00::)
Dazn: Failed (Network Connection)
TikTok: Failed
Amazon Prime Video: Unsupported
TVBAnywhere+: Failed (Network Connection)
iQyi Oversea Region: Failed
Steam Currency: Failed (Network Connection)
ChatGPT: Failed
Bing Region: HK
---Forum---
Reddit: Failed (Network Connection)
Now E: Failed (Network Connection)
Viu.com: Failed
Viu.TV: Failed (Network Connection)
MyTVSuper: No
HBO GO Asia: Failed (Network Connection)
BiliBili Hongkong/Macau/Taiwan: Failed (Network Connection)
[/tab]
[tab="响应"]
正在测试 https://www.google.com
尝试 1: 83.401000 ms
尝试 2: 85.763000 ms
尝试 3: 69.092000 ms
尝试 4: 74.817000 ms
尝试 5: 83.717000 ms
平均时间: 79.35 ms for https://www.google.com
正在测试 https://www.facebook.com
尝试 1: 202.951000 ms
尝试 2: 184.382000 ms
尝试 3: 201.179000 ms
尝试 4: 191.609000 ms
尝试 5: 197.897000 ms
平均时间: 195.60 ms for https://www.facebook.com
正在测试 https://www.twitter.com
尝试 1: 261.623000 ms
尝试 2: 261.164000 ms
尝试 3: 261.522000 ms
尝试 4: 259.843000 ms
尝试 5: 260.710000 ms
平均时间: 260.97 ms for https://www.twitter.com
正在测试 https://www.youtube.com
尝试 1: 202.929000 ms
尝试 2: 192.672000 ms
尝试 3: 137.937000 ms
尝试 4: 116.653000 ms
尝试 5: 192.828000 ms
平均时间: 168.60 ms for https://www.youtube.com
正在测试 https://www.netflix.com
尝试 1: 519.698000 ms
尝试 2: 532.072000 ms
尝试 3: 576.702000 ms
尝试 4: 524.201000 ms
尝试 5: 544.229000 ms
平均时间: 539.38 ms for https://www.netflix.com
正在测试 https://chat.openai.com
尝试 1: 39.650000 ms
尝试 2: 67.288000 ms
尝试 3: 43.234000 ms
尝试 4: 32.244000 ms
尝试 5: 34.062000 ms
平均时间: 43.29 ms for https://chat.openai.com
正在测试 https://www.github.com
尝试 1: 113.401000 ms
尝试 2: 125.264000 ms
尝试 3: 110.147000 ms
尝试 4: 124.528000 ms
尝试 5: 119.609000 ms
平均时间: 118.58 ms for https://www.github.com
网站                          平均时间(ms)
https://www.google.com                79.35 ms
https://www.facebook.com             195.60 ms
https://www.twitter.com              260.97 ms
https://www.youtube.com              168.60 ms
https://www.netflix.com              539.38 ms
https://chat.openai.com               43.29 ms
https://www.github.com               118.58 ms
Total Avg                            200.82 ms
[/tab]
[tab="多线程测速"]
------------------------ 多功能 自更新 测速脚本 ------------------------
Version               : v2024-04-25
Usage                 : bash <(curl -sL bash.icu/speedtest)
GitHub                : https://github.com/i-abc/speedtest
测速节点            下载/Mbps      上传/Mbps      延迟/ms      抖动/ms
最近的测速点        383.17 Mbps    321.36 Mbps    1.64 ms      0.15 ms
电信 江苏苏州       2257.77 Mbps   2.56 Mbps      303.67 ms    0.16 ms
电信 浙江杭州       1000.61 Mbps   1.18 Mbps      315.90 ms    2.69 ms
电信 安徽合肥 5G    1356.68 Mbps   0.88 Mbps      314.07 ms    2.18 ms
电信 浙江宁波 5G    1923.86 Mbps   2.15 Mbps      294.93 ms    2.50 ms
电信 江苏镇江 5G    2464.17 Mbps   1.26 Mbps      304.63 ms    4.59 ms
电信 江苏南京 5G    1367.65 Mbps   2.82 Mbps      313.63 ms    1.54 ms
测速次数过多,暂时被限制,请过一段时间后再进行测试
教育网 北京           失败         360.38 Mbps    121.09 ms    59.35 ms
教育网 上海 1       18.49 Mbps     10.94 Mbps     62.27 ms     0.63 ms
教育网 上海 2       17.00 Mbps     133.88 Mbps    60.00 ms      失败
教育网 江苏南京 1   653.20 Mbps    750.24 Mbps    69.45 ms     4.35 ms
系统时间:2024-07-01 15:47:22 UTC
北京时间: 2024-07-01 23:47:22 CST
[/tab]
[tab="单线程测速"]
电信 四川成都       15.10 Mbps     0.10 Mbps      328.60 ms    6.60 ms
电信 江苏苏州       78.80 Mbps     4.30 Mbps      297.60 ms    11.20 ms
电信 浙江杭州       7.40 Mbps      1.90 Mbps      305.20 ms    15.00 ms
电信 安徽合肥 5G    11.70 Mbps     0.80 Mbps      311.50 ms    20.00 ms
电信 浙江宁波 5G      失败         0.80 Mbps      296.70 ms    19.00 ms
电信 江苏镇江 5G    78.30 Mbps     0.20 Mbps      309.00 ms    4.70 ms
电信 江苏南京 5G    73.70 Mbps     1.20 Mbps      286.70 ms    22.70 ms
移动 浙江杭州 5G      失败         1.00 Mbps      38.00 ms     24.20 ms
联通 江苏无锡         失败           失败         85.70 ms     15.30 ms
广电 重庆             失败           失败         277.70 ms    0.50 ms
系统时间:2024-07-01 16:08:12 UTC
北京时间: 2024-07-02 00:08:12 CST
[/tab]
[tab="回程路由"]
No:1/9 Traceroute to 中国 深圳 电信 (TCP Mode, Max 30 Hop, IPv4)
NextTrace v1.3.1 2024-05-31T02:04:05Z f303397
[NextTrace API] preferred API IP - [2606:4700:3037::ac43:9bc0] - 53.44ms - Misaka.HKG
traceroute to 59.36.216.1, 30 hops max, 52 bytes payload
1 38.181.76.1 AS138997 中国 香港 eons.cloud
0.34 ms
2 103.138.72.21 AS138997 [EDCL-HK] 中国 香港 eons.cloud
0.86 ms
3 103.138.72.98 AS138997 [EDCL-HK] 中国 香港 eons.cloud
2.59 ms
4 103.138.72.94 AS138997 [EDCL-HK] 中国 香港 eons.cloud
0.33 ms
5 103.138.72.91 AS138997 [EDCL-HK] 中国 香港 eons.cloud
2.63 ms
6 103.138.72.9 AS138997 [EDCL-HK] 中国 香港 eons.cloud
0.73 ms
7 103.138.72.58 AS138997 [EDCL-HK] 中国 香港 eons.cloud
0.71 ms
8 *
9 *
10 *
11 202.97.27.241 AS4134 [CHINANET-BB] 中国 广东 广州 X-I www.chinatelecom.com.cn 电信
395.04 ms
12 *
13 *
14 *
15 119.147.61.50 AS4134 [CHINANET-GD] 中国 广东 深圳 www.chinatelecom.com.cn
329.43 ms
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 172.67.155.192 - 42.41ms - Misaka.HKG
traceroute to 101.226.41.65, 30 hops max, 52 bytes payload
0.27 ms
2 103.138.72.23 AS138997 [EDCL-HK] 中国 香港 eons.cloud
0.67 ms
3 103.138.72.26 AS138997 [EDCL-HK] 中国 香港 eons.cloud
1.77 ms
0.71 ms
3.78 ms
0.71 ms
0.82 ms
8 *
9 *
10 4.15.125.54 AS3356 美国 加利福尼亚 圣何塞 Level3-CT-Peer lumen.com
174.92 ms
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - 172.67.155.192 - 44.57ms - Misaka.HKG
traceroute to 220.181.53.1, 30 hops max, 52 bytes payload
0.29 ms
0.73 ms
3 103.138.72.20 AS138997 [EDCL-HK] 中国 香港 eons.cloud
2.54 ms
4 103.138.72.90 AS138997 [EDCL-HK] 中国 香港 eons.cloud
3.38 ms
1.51 ms
0.88 ms
1.09 ms
8 *
9 *
210.82 ms
11 *
12 *
13 *
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
No:4/9 Traceroute to 中国 广州 联通 (TCP Mode, Max 30 Hop, IPv4)
[NextTrace API] preferred API IP - 104.21.40.176 - 46.53ms - Misaka.HKG
traceroute to 210.21.4.130, 30 hops max, 52 bytes payload
0.31 ms
0.66 ms
3 103.138.72.22 AS138997 [EDCL-HK] 中国 香港 eons.cloud
1.86 ms
4 103.138.72.92 AS138997 [EDCL-HK] 中国 香港 eons.cloud
0.59 ms
5 103.138.72.95 AS138997 [EDCL-HK] 中国 香港 eons.cloud
3.79 ms
0.46 ms
7 103.138.72.19 AS138997 [EDCL-HK] 中国 香港 eons.cloud
47.94 ms
8 206.148.24.125 AS7578 日本 东京都 东京 globalsecurelayer.com
47.97 ms
9 206.148.22.136 AS136510 新加坡 Streamline Servers Pty Ltd
47.89 ms
10 *
11 *
12 *
13 *
14 206.148.24.36 AS7578 日本 东京都 东京 globalsecurelayer.com
48.05 ms
15 *
16 *
17 *
18 *
19 221.111.202.70 AS17676 [BBTEC] 中国 北京 softbank.jp
160.77 ms
20 219.158.9.226 AS4837 [CU169-BACKBONE] 中国 北京 chinaunicom.cn 联通
153.28 ms
21 *
22 219.158.108.242 AS4837 [CU169-BACKBONE] 中国 广东 广州 chinaunicom.cn 联通
147.04 ms
23 120.83.0.234 AS17816 [APNIC-AP] 中国 广东 广州 chinaunicom.cn 联通
175.31 ms
24 120.80.79.186 AS17622 [APNIC-AP] 中国 广东 广州 chinaunicom.cn 联通
167.57 ms
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - [2606:4700:3031::6815:28b0] - 48.87ms - Misaka.HKG
traceroute to 112.65.95.129, 30 hops max, 52 bytes payload
0.30 ms
0.89 ms
2.04 ms
0.35 ms
2.54 ms
0.36 ms
47.91 ms
48.08 ms
47.97 ms
10 *
11 *
12 *
13 *
47.94 ms
15 *
16 *
17 *
18 *
148.85 ms
20 219.158.16.69 AS4837 [CU169-BACKBONE] 中国 北京 chinaunicom.cn 联通
141.65 ms
21 *
22 *
23 139.226.210.94 AS17621 [UNICOM-SH] 中国 上海 chinaunicom.cn 联通
179.03 ms
24 210.22.66.174 AS17621 [APNIC-AP] 中国 上海 chinaunicom.cn 联通
200.82 ms
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - [2606:4700:3037::ac43:9bc0] - 53.91ms - Misaka.HKG
traceroute to 61.49.140.217, 30 hops max, 52 bytes payload
0.32 ms
0.70 ms
3.35 ms
0.40 ms
2.13 ms
0.52 ms
47.84 ms
47.89 ms
9 206.148.22.137 AS136510 新加坡 Streamline Servers Pty Ltd
47.92 ms
10 *
11 *
12 *
13 *
47.89 ms
15 *
16 *
17 *
18 *
159.68 ms
20 219.158.9.185 AS4837 [CU169-BACKBONE] 中国 北京 chinaunicom.cn
166.26 ms
21 *
22 125.33.186.46 AS4808 [UNICOM-BJ] 中国 北京 中国联通 联通
193.89 ms
23 *
24 61.49.140.217 AS4808 中国 北京 中国联通 联通
180.95 ms
No:7/9 Traceroute to 中国 深圳 移动 (TCP Mode, Max 30 Hop, IPv4)
[NextTrace API] preferred API IP - 104.21.40.176 - 49.89ms - Misaka.HKG
traceroute to 120.233.53.1, 30 hops max, 52 bytes payload
0.32 ms
0.80 ms
2.85 ms
0.31 ms
2.37 ms
0.75 ms
0.99 ms
8 *
9 4.69.218.146 AS3356 中国 香港 lumen.com
4.10 ms
10 223.121.3.9 AS58453 [CMI-INT] 中国 香港 cmi.chinamobile.com 移动
6.96 ms
11 223.120.22.69 AS58453 [CMI-INT] 中国 香港 cmi.chinamobile.com 移动
3.64 ms
12 *
13 221.183.92.189 AS9808 [CMNET] 中国 安徽 合肥市 chinamobileltd.com 移动
10.10 ms
14 221.183.92.213 AS9808 [CMNET] 中国 广东 广州 chinamobileltd.com 移动
17.54 ms
15 *
16 *
17 211.136.242.174 AS56040 [CMNET] 中国 广东 广州 chinamobile.com 移动
71.00 ms
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - [2606:4700:3037::ac43:9bc0] - 49.33ms - Misaka.HKG
traceroute to 183.194.216.129, 30 hops max, 52 bytes payload
0.33 ms
0.81 ms
2.45 ms
4 103.138.72.96 AS138997 [EDCL-HK] 中国 香港 eons.cloud
0.55 ms
3.05 ms
0.70 ms
0.64 ms
8 *
5.76 ms
10 *
11 223.120.2.117 AS58453 [CMI-INT] 中国 香港 cmi.chinamobile.com 移动
6.81 ms
12 *
13 221.183.89.182 AS9808 [CMNET] 中国 上海 chinamobileltd.com 移动
53.53 ms
14 *
15 *
16 *
17 *
18 *
19 *
20 *
21 *
22 *
23 *
24 *
25 *
26 *
27 *
28 *
29 *
30 *
[NextTrace API] preferred API IP - [2606:4700:3037::ac43:9bc0] - 46.62ms - Misaka.HKG
traceroute to 211.136.25.153, 30 hops max, 52 bytes payload
0.25 ms
0.70 ms
2.83 ms
0.54 ms
3.71 ms
0.94 ms
0.92 ms
8 *
1.99 ms
10 *
3.73 ms
12 *
13 221.183.55.102 AS9808 [CMNET] 中国 北京 X-I chinamobileltd.com 移动
81.26 ms
14 221.183.46.250 AS9808 [CMNET] 中国 北京 chinamobileltd.com 移动
82.02 ms
15 221.183.89.98 AS9808 [CMNET] 中国 北京 chinamobileltd.com 移动
85.04 ms
16 *
17 *
18 *
19 211.136.95.226 AS56048 [CMNET] 中国 北京 chinamobile.com 移动
67.82 ms
20 *
21 *
22 211.136.25.153 AS56048 [CMNET] 中国 北京 chinamobile.com 移动
70.03 ms
[/tab]
[tab="去程路由"]
[/tab]
[tab="iperf3"]
[/tab]
[tab="Ping.pe"]
[/tab]
[tab="哪吒 ICMP"]
[/tab]
[tab="其他"]
[/tab]
[/tabs]
海外原生IP VPS,稳定访问全球网络
lisahost.com 了解更多
6 条回复
  1. fengzai 荣誉版主 王者 2024-07-02
    这延迟有点吓人:ac10:
  2. mumu666 白银 2024-07-02
    新商家?观望再说。。。
  3. everett7623 王者 楼主 MANAGER 2024-07-02
    是的啊,很新的,我来踩坑的,其他还未添加数据
  4. QAQ555 白银 2024-07-05
    延迟感人,深移怎么要71ms
  5. SmileTone 白银 2024-07-05
    线路一般,只能当落地机。
  6. everett7623 王者 楼主 MANAGER 2024-07-05
    直连也可以啊,虽然延迟感人。
