云湖机器人(需下载云湖APP)
效果图:
直接体验:
https://yhfx.jwznb.com/share?key=YZInMjHRY6c2&ts=1745027189
部署(需python3.12)
依赖包:
```plaintext
blinker==1.9.0
certifi==2025.1.31
charset-normalizer==3.4.1
click==8.1.8
filetype==1.2.0
Flask==3.1.0
idna==3.10
itsdangerous==2.2.0
Jinja2==3.1.6
MarkupSafe==3.0.2
requests==2.32.3
urllib3==2.4.0
Werkzeug==3.1.3
部署sdkFrame
```shell
git clone https://github.com/runoneall/sdkFrame.git
python3 -m sdkFrame -add-origin https://dev.oneall.eu.org/ryhsdk2/map.json -update-origin -set-env YUNHU_TOKEN=云湖机器人token -set-env 'SERVER=json:{ 1 ↵
"host": "0.0.0.0",
"port": 端口,
"debug": true,
"threaded": true
python3 -m sdkFrame -install-module SendMessage@r1a-ryhsdk2
python3 -m sdkFrame -install-module ServCommand@r1a-ryhsdk2 -install-module ServShortCut@r1a-ryhsdk2
`AliceAPI.py`
```python
import requests
class EphemeraAPI:
def init(self, api_token):
self.EVO_API_BASE = “Alice Networks”
self.api_header = {“KP-APIToken”: api_token}
def EvoJob(self, job_name):
return self.EVO_API_BASE + job_name
def InstanceList(self):
resp = requests.get(self.EvoJob("Instance"), headers=self.api_header).json()
if resp["status"] != 200:
return None
return resp["data"]
def PlanList(self):
resp = requests.get(self.EvoJob("Plan"), headers=self.api_header).json()
return None
PlanMap = {}
for plan in resp["data"]:
PlanMap[plan["name"]] = plan["id"]
return PlanMap
def PlanOsList(self, plan_id):
resp = requests.post(
self.EvoJob("PlanToOS"),
headers=self.api_header,
data={"plan_id": str(plan_id)},
).json()
return None
OSMap = {}
for _, osGroup in resp["data"].items():
for osItem in osGroup["os"]:
OSMap[osItem["name"]] = osItem["id"]
return OSMap
def InstanceDeploy(self, plan_id, os_id, hours):
self.EvoJob("Deploy"),
data={"product_id": str(plan_id), "os_id": str(os_id), "time": str(hours)},
).json()
return None
return resp["data"]
def InstanceDestroy(self, instance_id):
self.EvoJob("Destroy"),
data={"id": str(instance_id)},
).json()
return False
return True
def InstancePower(self, instance_id, action):
self.EvoJob("Power"),
data={"id": str(instance_id), "action": str(action)},
).json()
return False
return True
def InstanceRebuild(self, instance_id, os_id):
self.EvoJob("Rebuild"),
data={"id": str(instance_id), "os": str(os_id)},
).json()
return False
return resp["data"]
def InstanceRenewal(self, instance_id, hours):
self.EvoJob("Renewal"),
data={"id": str(instance_id), "time": str(hours)},
).json()
return False
return True<i>
到 https://www.yhchat.com/control 创建机器人
快捷菜单设置(全部为普通按钮,事件推送)
名称随意,记录菜单id
指令列表
添加一个普通指令和一个自定义输入指令,名称随意,记录id
自定义输入表单(名称随意,记录id)
```plaintext
Plan选项
LAX.Evo.Micro#LAX.Evo.Standard#LAX.Evo.Pro#LAX.Evo.Ultra
OS选项
Debian 12 (Bookworm) Minimal#Debian 11 (Bullseye) Minimal#Debian 12 DevKit#Ubuntu Server 20.04 LTS Minimal#Ubuntu Server 22.04 LTS Minimal#CentOS 7 Minimal#CentOS Stream 9 Minimal#AlmaLinux 8 Minimal#AlmaLinux 9 Latest#Alpine Linux 3.19
`app.py`
```python
import json
import os
import sdkFrame
import AliceAPI
sdk = sdkFrame.init()
if not os.path.exists(“db.json”):
with open(“db.json”, “w”, encoding=“utf-8”) as f:
f.write(“{}”)
def ReadDB():
with open(“db.json”, “r”, encoding=“utf-8”) as f:
return json.load(f)
def WriteDB(data_dict):
json.dump(data_dict, fp=f, indent=2, ensure_ascii=True)
def SetToken(data):
event = data[“event”]
if event[“chat”][“chatType”] == “bot”:
uid = event[“sender”][“senderId”]
token = event[“message”][“content”][“text”]
WriteDB({**ReadDB(), **{uid: {“token”: token}}})
sdk.SendMessage.Text(uid, “user”, f"Set {uid} Token {token}")
def InstanceConfig(data):
formJson = event[“message”][“content”][“formJson”]
target_plan = formJson[“Plan 选择框表单ID”][“selectValue”]
target_os = formJson[“OS 选择框表单ID”][“selectValue”]
target_hours = formJson[“Hours 输入框表单ID”][“value”]
db = ReadDB()
if uid in db and "token" in db[uid]:
db[uid]["plan"] = target_plan
db[uid]["os"] = target_os
db[uid]["hours"] = target_hours
WriteDB(db)
uid,
"user",
f"""Default Config:
- Plan: {target_plan}
- OS: {target_os}
- Hours: {target_hours}“”",
else:
sdk.SendMessage.Text(uid, “user”, “Set Token First”)
def InstanceInfo(data):
if event[“senderType”] == “user”:
db = ReadDB()
uid = event["senderId"]
if uid not in db or "token" not in db[uid]:
sdk.SendMessage.Text(uid, "user", "Set Token First")
return
if "instance_id" not in db[uid]:
db[uid]["instance_id"] = ""
if db[uid]["instance_id"] == "":
sdk.SendMessage.Text(uid, "user", "No Instance Deployed")
return
instance_id = db[uid]["instance_id"]
sdk.SendMessage.Text(uid, "user", f"Checking Instance {instance_id}...")
resp = AliceAPI.EphemeraAPI(db[uid]["token"]).InstanceList()
if resp == None:
sdk.SendMessage.Text(uid, "user", "Check Failed")
return
for instance in resp:
if str(instance["id"]) == instance_id:
uid,
"user",
f"""Server {instance_id}:
- Ipv4: {instance[“ipv4”]}
- Ipv6: {instance[“ipv6”]}
- Hostname: {instance[“hostname”]}
- Cpu Total: {instance[“cpu”]} Core
- Cpu Type: {instance[“cpu_name”]}
- Memory Total: {instance[“memory”]} MB
- Disk Total: {instance[“disk”]} GB
- Disk Type: {instance[“disk_type”]}
- User: {instance[“user”]}
- Password: {instance[“password”]}
- Status: {instance[“status”]}
- Created At: {instance[“creation_at”]}
- Expired At: {instance[“expiration_at”]}
- Plan: {instance[“plan”]}
- Region: {instance[“region”]}
- OS: {instance[“os”]}“”",
break
def InstanceDeploy(data):
db = ReadDB()
return
if "plan" not in db[uid] or "os" not in db[uid] or "hours" not in db[uid]:
sdk.SendMessage.Text(uid, "user", "Set Default Config First")
return
if "instance_id" in db[uid] and db[uid]["instance_id"] != "":
sdk.SendMessage.Text(uid, "user", "Instance Already Deployed")
return
sdk.SendMessage.Text(uid, "user", "Deploying Instance...")
target_plan = db[uid]["plan"]
target_os = db[uid]["os"]
target_hours = db[uid]["hours"]
Ephemera = AliceAPI.EphemeraAPI(db[uid]["token"])
plans = Ephemera.PlanList()
oss = Ephemera.PlanOsList(plans[target_plan])
resp = Ephemera.InstanceDeploy(
Ephemera.PlanList()[target_plan], oss[target_os], hours=int(target_hours)
if resp == None:
sdk.SendMessage.Text(uid, "user", "Deploy Failed")
return
db[uid]["instance_id"] = str(resp["id"])
WriteDB(db)
uid,
"user",
f"Instance {resp['id']} Deployed, Please Wait for 2-3 minutes, Use Info Button to Check Status",
def InstanceDestroy(data):
db = ReadDB()
return
if "instance_id" not in db[uid] or db[uid]["instance_id"] == "":
return
sdk.SendMessage.Text(uid, "user", f"Destroying Instance {instance_id}...")
resp = AliceAPI.EphemeraAPI(db[uid]["token"]).InstanceDestroy(instance_id)
if resp == False:
sdk.SendMessage.Text(uid, "user", "Destroy Failed")
return
del db[uid]["instance_id"]
WriteDB(db)
sdk.SendMessage.Text(uid, "user", f"Instance {instance_id} Destroyed")
def power_action(data, action):
db = ReadDB()
return
return
uid, "user", f"Performing {action} on Instance {instance_id}..."
resp = AliceAPI.EphemeraAPI(db[uid]["token"]).InstancePower(instance_id, action)
if resp == False:
sdk.SendMessage.Text(uid, "user", f"{action} Failed")
return
sdk.SendMessage.Text(uid, "user", f"Instance {instance_id} {action}ed")
def InstanceBoot(data):
power_action(data, “boot”)
def InstanceShutdown(data):
power_action(data, “shutdown”)
def InstanceRestart(data):
power_action(data, “restart”)
def InstancePoweroff(data):
power_action(data, “poweroff”)
def InstanceRebuild(data):
db = ReadDB()
return
if "plan" not in db[uid] or "os" not in db[uid]:
return
return
sdk.SendMessage.Text(uid, "user", f"Rebuilding Instance {instance_id}...")
oss = Ephemera.PlanOsList(plans[db[uid]["plan"]])
resp = Ephemera.InstanceRebuild(instance_id, oss[db[uid]["os"]])
if resp == False:
sdk.SendMessage.Text(uid, "user", "Rebuild Failed")
return
sdk.SendMessage.Text(uid, "user", f"Instance {instance_id} Rebuilt")
def InstanceRenewal(data):
db = ReadDB()
return
return
sdk.SendMessage.Text(uid, "user", f"Renewing Instance {instance_id}...")
resp = AliceAPI.EphemeraAPI(db[uid]["token"]).InstanceRenewal(
instance_id, int(target_hours)
if resp == False:
sdk.SendMessage.Text(uid, "user", "Renewal Failed")
return
uid, "user", f"Instance {instance_id} Renewed {target_hours} hours"
sdk.ServCommand.AddHandle(SetToken, Set Token 指令ID)
sdk.ServCommand.AddHandle(InstanceConfig, Default Config 指令ID)
sdk.ServShortCut.AddHandle(InstanceInfo, “Info 菜单ID”)
sdk.ServShortCut.AddHandle(InstanceDeploy, “Deploy 菜单ID”)
sdk.ServShortCut.AddHandle(InstanceDestroy, “Destroy 菜单ID”)
sdk.ServShortCut.AddHandle(InstanceBoot, “Boot 菜单ID”)
sdk.ServShortCut.AddHandle(InstanceShutdown, “Shutdown 菜单ID”)
sdk.ServShortCut.AddHandle(InstanceRestart, “Restart 菜单ID”)
sdk.ServShortCut.AddHandle(InstancePoweroff, “Poweroff 菜单ID”)
sdk.ServShortCut.AddHandle(InstanceRebuild, “Rebuild 菜单ID”)
sdk.ServShortCut.AddHandle(InstanceRenewal, “Renewal 菜单ID”)
sdk.Server.AddTrigger(sdk.ServCommand)
sdk.Server.AddTrigger(sdk.ServShortCut)
sdk.Server.Start()
启动后填入到 `配置消息订阅接口`
