用闲置serv00搭建小游戏网站,保姆级图片教程。(全程不用SSH连接),求心心💖
1. First, we need to bind a domain name (if you are using the domain provided by serv00, skip this step and go directly to step 3)
① Add website
② Copy the IP of the A record
③ Point to CF (or another DNS hosting provider)
2. Upload the 15‑year certificate provided by CF (or your own certificate) to serv00; a CF certificate works as long as you turn on the orange cloud. (This step can be ignored; you can go without it.)
① Create a certificate in CF (or use your own certificate)
② In the SSL section, find the IP we just pointed to – click Manage
③ Upload the certificate to serv00
3. Upload files from the GitHub repository
① Open File Manager → your domain folder → public_html → delete the index.html file
② Upload the GitHub zip file
Author’s repository: hackycy/h5-game-collection: :video_game: 80 H5 mini‑games collection purchased on Taobao
Download it
Upload it
③ Extract the files to the root directory
屏幕截图 2025-06-25 210302
4. Done
Pretty simple, but why does writing the tutorial feel so complicated… :xhj27:
Previously set up site: https://ccyycc.eu.org
感谢分享~有用 :xhj003:
CF免费计划好像上传不了自己的证书吧
我的意思是把CF给你提供15年证书上传到serv00,只要开小黄云就能用。
感谢大佬的教程! :xhj26:
完工! :xhj26:
受教了。。。
好用点赞了
可以可以,有得玩了
牛逼。。每日求一赞
打开小黄云,还需要上传证书吗?我的域名只要在cf上解析至serv00站点,就没管过证书了。
这个可以啊
我的SSL设置是【完全严格】,所以需要证书加密。
设置【灵活】可以不用证书也能https,但安全性较差。
如果不太在意的话,http裸奔也行 :xhj21:
我设置的就是【灵活】 :xhj09:
帖子无法编辑了,需要说明一下,那个 用于演示的lllllllllll.eu.org域名已经从serv00删除了。
:xhj15::xhj15::xhj15:
可惜!我没有
怎么注册这个?我的梯子注册不了
Thank you
Thank you for sharing~
好教程
