This browser is not supported.
Yes, it is said that the reason is that Discourse is relatively aggressive.
没有解决办法吗,我手机浏览器版本较低,之后只能在电脑上看了
Just switch browsers! It keeps prompting that it’s a low version! Can’t you just switch to a higher version?
Change phone, or upgrade the system..
电脑或手机太旧导致操作系统版本太老,无法更新的新版本的操作系统,比如我的电脑还是Win7,操作系统太老就会导致浏览器无法升级到高版本,富有限制了你的想象力![]()
Switch to Firefox, Firefox support on low‑spec machines is still decent.
Why not eat meat porridge ![]()
Exactly! Can’t we use fingerprint?
I have also encountered it; installing the Edge browser on my phone solved it.
I remember there was a problem before, wasn’t it fixed? Why is it happening again?》
You’re using the Kiwi browser, right?
Both the HarmonyOS browser and the Quark browser cannot access it; you need to install a higher‑version browser separately.
On Windows 7, there is a Google browser with a modified kernel version that can be installed and access the forum normally.
Switch browsers. The last time I used Kiwi it also didn’t work. Then I switched to Edge browser.
I haven’t encountered this problem.
