Free hosted Cloudflare domain, register with just one email
测试可托管cloudflare,就是域名长了点
注册一个账号,邮箱可以用qq,163,126之类的,能收验证码邮件应该就行,然后点注册新域名,再点可托管cloudflare域名,几个域名里面随便挑一个(都挺长的),点立即注册,再点确认注册就行,之后点我的域名就可以看到你注册的域名,把域名复制下来到cloudflare仪表板添加,会提示没有DNS记录,是正常的,直接下一步即可,然后cloudflare会给两条ns记录,复制下来,回到前面我的域名那一页,点DNS管理,之后把cloudflare给的记录分别粘贴进去,点保存NS记录,之后回到cloudflare仪表板,点检查名称服务器,再等几分钟就可以了
还有个事,cloudflare似乎没法给这些域名下ssl证书,手动调Let’s Encrypt的ACME接口下证书会报错, Google Trust Services和ZeroSSL没测,不确定可不可以
The domain you said can be hosted on CF is ip6.arpa :downcast_face_with_sweat:
Thank you for sharing, boss
Thank you, OP, for sharing the domain name.
Not bad, not bad, I’ll give it a try.
Thanks for sharing, I’ll try it right away.
It’s ip6.arpa.
This cannot apply for a certificate
Which platform provides domain names with the ip6.arpa suffix? It appears so frequently.
I don’t need this one. Thanks for sharing.
I made something in CF; as long as it works, thanks to the OP.
I thought the .cn domain could be bound.
可以申请,ssl.com支持
Is this kldns?
Free
Is it that good?
Thanks for sharing, it’s already enough for use.
Since you said it’s long, I guess it’s an IPv6 tunnel domain name.
