Request Timeout
This request takes too long to process, it is timed out by the server. If it should not be timed out, please contact administrator of this web site to increase ‘Connection Timeout’.
All the same It was great at first, pretty smooth Then it got increasingly laggy
It’s only been half a year.
Luckily I didn’t get on the vehicle, I’m extremely sad.
What configuration? The server that was 99 during the last Double Eleven, I’m planning to drop it when it expires.
This is the 199’s 2C4G, EC2 is really poor, not even as good as the 99’s.
Domestic stuff, sigh, I won’t say more.
I’ve been using Alibaba Cloud’s domestic lightweight instances and haven’t encountered any problems, except that when I first tried the machine, the OS image of the lowest‑spec configuration had an issue.
It could be at first, but later it was always like this.
Aliyun has agreed to a refund; the server isn’t great, but the service is still fine.
Big companies are generally better than fly‑by‑night ones, right?
If it could be refunded, that would be great. It’s frustrating.
If you don’t buy Alibaba Cloud, you can get two abroad. I originally thought that a big domestic company would have stable servers, but the stability is questionable—many places overseas can’t access them at all, not even connect, and it’s not just a slow speed issue. I’m really frustrated; if the server can’t connect, can it even be called a server? A larger LAN.
Tencent’s is passable; they even changed the IP after submission. As for Alibaba Cloud, aside from their attitude, everything else is terrible.
AlibabaCloud
