It should be a platform like Claw, with a $5 monthly limit
邀请链接:https://zeabur.com/referral?referralCode=bye1158
PS:貌似需要绑个手机或者虚拟卡才可以用,刚看到,没测试
I’ve been using it for a long time, but the billing is a bit high.
The information is well-informed, and it seems this kind is all very high.
The main issue is that its memory usage and similar cannot be limited, so it can easily exceed the budget.
很早之前就偷吃上了,桀桀桀,xdm轻点蹬,别成第二个爪云:sob:
Never used it, is it fun?
How can the guy also use this to set up a probe :ac01:
How’s the direct connection performance?
Because it’s so handy :xhj003:
Thanks for sharing
This platform has restrictions.
I think I registered early.
Binding a card requires a relatively high verification difficulty, so I don’t even dare to bind it like this :ac01:
It’s an overseas phone. Or a virtual card.
I heard we have to link a card.
Not very easy to handle
Probably no card verification is needed; try a dummy card? I’m using a phone.
or receive the code on a phone
这个怎么搭建探针,可以详细说说吗?
