Change the post’s notification mode. This issue is from the official side; we’ll fix it later.
After clicking to join, it defaults to following; just unfollow.
LeBron says it’s an official issue, weird that I don’t have it.
Setting it to General works fine.
I also set it to normal, but it’s still there…
Waiting for this issue to be fixed.
The push queue got jammed before the regular change, causing the queue before your change to keep pushing. Once the earlier pushes are finished, the later ones won’t push anymore~
Sorry, the admin is also fixing it.
