I just rebuilt the forum’s “chick,” but why am I not receiving any emails? Does anyone know? The backend password‑reset setting says the email was sent successfully, yet I still don’t receive it.
Can’t receive normally, a few days ago the mailbox got stuck with 400k emails, when will this be resolved? Using an SSH key is just ![]()
Log in using a key
Ah, this…
Just wait a day or two!
Alright, we can only use the key now.
Just use the key, I won’t wait.
I tried! It didn’t work! Then I didn’t try again!
Just use the key directly!! It’s more hassle‑free.
Rebuilt to use a key
Yes, it was rebuilt again
Reinstall the system, then set the key.
If you can’t wait, use the key first.
I listened to you, already used the key, haha
Okay, already used.
This topic was automatically closed 60 minutes after the last reply. No new replies are allowed.
