Forum 小鸡 password reset email not received!
Forum Little Chicken password reset email not received!
Use an SSH key~
This email notification often has problems
key I use XTerminal to upload directly, it’s quite handy.
Just use the key directly! Emails often don’t get delivered.
Reinstall the system then configure the key
MiQian cannot send email
Log in with a key
Use the key
Can only reinstall using the key now.
I already asked, you can only add an SSH key for use; the mail system has a problem
Most forum feedback is not received, can only log in with a key.
Yes, switched to using a key.
