My chatgpt is broken too, not only dumb but also stubborn.
:xhj30: :xhj004:
:xhj30: :xhj004:
Change the home broadband IP
Feels like the AI’s been poisoned
:ac23:
Can’t afford it :xhj14:
:xhj43:
Using a fixed IP and logging in on a mobile device for a few days may help alleviate intelligence reduction.
I’m using the free version. When there’s still a free quota, it’ll search the web, but once that’s used up, it just makes stuff up. I guess the free model was intentionally poisoned.
That’s it then. If it really doesn’t work, just go back to using Google Search. The IPs of CCS are insanely dirty.
It’s still better than Deepseek, just don’t change IPs too often.
I used deepseek when it first came out, but haven’t really used it much since then.
So stubborn!
When it first came out, it was pretty good, but now it’s basically dead.
Haha, that’s just how the free version is. If you’re going to use something for free, I think GEMINI actually works pretty well.
Then I’ll try using Gemini.
Lately, it feels like all the AIs have gotten dumber. Yesterday I tried writing some simple HTML code, and damn, I switched between several AIs and none of them got it right.
The weather has gotten colder, so I probably caught a cold.
How do you use Gemini?
Want to upgrade
I can’t afford to switch.
The tone of this reply is clearly off.
