[FutureNEXT Public Cloud Platform] Last time the NLers were overly enthusiastic; now we’re launching US‑region LXC (with permanent models) and Hong Kong‑region LXC! Balance can be obtained for free—take a look if you need it.
What’s the user’s email?
[email protected]
If there’s an issue, submit a ticket; otherwise, I’ll have a hard time seeing it.
It shows here that yours is turned on, it should be fine.
Let me show you.
Watching ads is such a waste of time.
I just remembered, it’s the Debian image that’s the problem; I’ll try switching it to Ubuntu for you.
Just spend it, it’s not expensive anyway.
I can’t give it away, because it’s already a loss‑making publicity stunt.
Alright, it’s connected, go try it.
The one‑time 1.5 that gets 300 GB per month?
Yeah, 300 GB per month, that should be right.
And it’s almost out of stock; if you want to buy, you should hurry.
Even after a day, I still can’t see 1.5 :ac01:
You can recharge, hehehe
Okay
Which disposable one can be used to climb a ladder?
If it works, just use it, and remember to encrypt.
Take a look
