Physical server with 32 GB RAM, new KS‑2 16 TB HDD, shipped from OVH French data center (CA region) with tax‑exempt number
Review:
8‑core 16‑thread, 32 GB RAM, 16 TB HDD super‑large physical server! Jackpot hard drive! New model KS‑2, upstream default 500 M (old model upstream 300 M)
Hard drive model is Western Digital Ultrastar® DC HC310, cache 256 MB, relatively new high‑performance HDD
Compared with OVH ordinary HDD, it’s not small; you can refer to my other HDD reviews for details. Detailed review can be seen at: https://blog.k8s.li/wd-hc310-dc-hdd.html
Unlimited traffic, very suitable for running Emby media servers, website hosting (with DDoS protection), remote development, DD Win, PT seeding, data backup and other scenarios.
Forum transactions have been done multiple times; the reputation can be trusted.
If you need it, you can private‑message or Telegram @xibalaw (prefer Telegram for a quicker reply). Renewal, email re‑binding and similar operations are fully guided.
Machine configuration:
CPU model: Intel(R) Xeon(R) CPU D-1541
CPU cores: 8 cores / 16 threads
Memory: 32 GB
Disk: 4 × 4 TB HDD
Network: 500 M upstream, 1 G downstream, IPv4 & IPv6 both normal and not blocked
Traffic: unlimited
Data center: IE region France data center
Renewal: $21.1 per month (equivalent to €18.99 in the IE region)
IPMI: with IPMI
Renewed until: December 13
YABS (disk raid0 mode):
Tue Nov 18 01:50:40 UTC 2025
Basic System Information:
Uptime     : 0 days, 14 hours, 54 minutes
Processor  : Intel(R) Xeon(R) CPU D-1541  2.10GHz
CPU cores  : 16  1800.240 MHz
AES-NI     : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM        : 31.2 GiB
Swap       : 0.0 KiB
Disk       : 14.6 TiB
Kernel     : 6.1.0-41-amd64
VM Type    : NONE
IPv6 Network Information:
ISP        : OVH SAS
ASN        : AS16276 OVH SAS
Host       : OVH
Country    : France
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md2):
Read       | 6.84 MB/s     (1.7k) | 67.14 MB/s    (1.0k)
Write      | 6.85 MB/s     (1.7k) | 67.46 MB/s    (1.0k)
Total      | 13.70 MB/s    (3.4k) | 134.61 MB/s   (2.1k)
Read       | 250.10 MB/s    (488) | 284.17 MB/s    (277)
Write      | 263.39 MB/s    (514) | 303.09 MB/s    (295)
Total      | 513.50 MB/s   (1.0k) | 587.27 MB/s    (572)
iperf3 Network Speed Tests (IPv4):
Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
Clouvider       | London, UK (10G)          | 484 Mbits/sec   | 941 Mbits/sec   | 3.81 ms
Eranium         | Amsterdam, NL (100G)      | 483 Mbits/sec   | 939 Mbits/sec   | 9.27 ms
Uztelecom       | Tashkent, UZ (10G)        | 447 Mbits/sec   | 776 Mbits/sec   | 102 ms
Leaseweb        | Singapore, SG (10G)       | 379 Mbits/sec   | 371 Mbits/sec   | 164 ms
Clouvider       | Los Angeles, CA, US (10G) | 389 Mbits/sec   | 661 Mbits/sec   | 143 ms
Leaseweb        | NYC, NY, US (10G)         | 412 Mbits/sec   | 766 Mbits/sec   | 76.8 ms
Edgoo           | Sao Paulo, BR (1G)        | 395 Mbits/sec   | 571 Mbits/sec   | 198 ms
iperf3 Network Speed Tests (IPv6):
Clouvider       | London, UK (10G)          | 478 Mbits/sec   | 928 Mbits/sec   | 3.80 ms
Eranium         | Amsterdam, NL (100G)      | 476 Mbits/sec   | 926 Mbits/sec   | 9.08 ms
Uztelecom       | Tashkent, UZ (10G)        | 416 Mbits/sec   | 718 Mbits/sec   | 102 ms
Leaseweb        | Singapore, SG (10G)       | 412 Mbits/sec   | 635 Mbits/sec   | 164 ms
Clouvider       | Los Angeles, CA, US (10G) | 395 Mbits/sec   | 722 Mbits/sec   | 143 ms
Leaseweb        | NYC, NY, US (10G)         | 409 Mbits/sec   | 730 Mbits/sec   | 76.8 ms
Edgoo           | Sao Paulo, BR (1G)        | 377 Mbits/sec   | 605 Mbits/sec   | 198 ms
Standalone Server Test Report (Hard drive performance is significantly better than standard HDD):
大盘鸡,看着是心动,但是荷包太紧
Dedicated Server Test Report (hard drive performance significantly stronger than standard HDD):
16T this price is not expensive :slight_smile:
Thanks for sharing, OP!
Come in and check out the review
16T large board, keep going.
