Latest Private Build FLUX.2 • Free to use • No API key required
If you have any issues or suggestions, please leave a comment, thank you
zeabur (free plan) deployment
Project address: GitHub - kinai9661/Puter
Getting Started - Puter.com Registration and Login
1. Register a free account (recommended)
When generating images, Puter.com login will automatically pop up, simply enlarge the window to see:
This is because it directly uses the official personal account’s API KEY for generation
FLUX.2 Image Generation
FLUX.2 Pro: High-quality, perfect text rendering, complex layout, and information graphics
FLUX.2 Flex: Flexible model, balancing speed and quality
FLUX.2 Dev: Development version, suitable for experimentation and testing
Later, Nano Banana (Gemini 3 Pro and 2.5 Flash Image) models will be added
Important Note: It is recommended to deploy and build yourself, as the official API has potential limitations
Free users have a generous quota suitable for general use, but high-frequency or long requests may trigger
