Utilizing koyeb to deploy high-performance nodes for free
Important Notice: Do not attempt to use this guide for any malicious purposes.
VIP Please Stop: xhj37:
Original Article: https://susu.vn.kg/40/2025
Advantages of this tutorial:
  • :white_check_mark: Zero Code: No coding required, no need to go to the black box to type commands.
  • :white_check_mark: No Syntax Errors: Using Base64 encoded configuration injection, solves syntax errors caused by punctuation marks.
  • :white_check_mark: Pure and Stable: Based on the official teddysun/xray Docker image, no backdoors, 24-hour background operation.
Preparation:
  • A registered Koyeb account. [Registration link:]
  • A pair of hands (only need to copy and paste).
Step 1: Create a Docker Service
  • Log in to the Koyeb console, click the Create Service button in the top right corner.
  • Select deployment method (choose Docker, icon is a small whale).
  • Docker image (image address):
    • Fill in the input box: teddysun/xray
  • Instance type (configuration):
    • Choose CPU EcO’s Micro (Free), this is permanently free.
  • Regions (region):
    • Only select Washington, D.C. or Frankfurt (do not select multiple).
Step 2: Inject Core Configuration (most critical step)
Scroll down and find Advanced (advanced) or click Deployment to expand settings. We need to modify the startup entry and startup command.
  • Find the Override Entrypoint (override entry point) input box, fill in: /bin/sh
  • Find the Override Command (override command) input box, copy and paste the following code:
-c "echo eyJpbmJvdW5kcyI6W3sicG9ydCI6ODAwMCwicHJvdG9jb2wiOiJ2bGVzcyIsInNldHRpbmdzIjp7ImRlY3J5cHRpb24iOiJub25lIiwiY2xpZW50cyI6W3siaWQiOiJkZTI0OWQ2Yi0wMDAwLTExMTEtMjIyMi0zMzMzNDQ0NDU1NTUifV19LCJzdHJlYW1TZXR0aW5ncyI6eyJuZXR3b3JrIjoid3MiLCJ3c1NldHRpbmdzIjp7InBhdGgiOiIvIn19fV0sIm91dGJvdW5kcyI6W3sicHJvdG9jb2wiOiJmcmVlZG9tIn1dfQ== | base64 -d > /etc/xray/config.json && /usr/bin/xray -config /etc/xray/config.json"
  • This command will automatically generate a UUID of de249d6b-0000-1111-2222-333344445555 VLESS configuration.
Step 3: Set Port
In the Ports (port) settings area:
  • Port: Change to 8000 (not 443, consistent with our configuration).
  • Protocol: Select HTTP.
  • Public path: Keep default /.
Step 4: Deployment and Verification
  • Click the Deploy button at the bottom of the page.
  • Wait 1-2 minutes, observe Build Logs.
  • When you see Service Status turn green Healthy, and the log shows Xray … started, it means deployment is successful!
  • Copy your domain name (e.g. my-site.koyeb.app) without https://
Step 5: Client Connection (must-read avoidance guide)
This is the final step for many crashes. Please strictly follow the parameters below, and any mistake will not connect.
Open your V2RayN / Shadowrocket / NekoBox:
  • Address (Address): Your application name.koyeb.app (do not add https://)
  • Port (Port): 443 (note! Fill in 443, do not fill 8000)
  • Protocol (Protocol): VLESS
  • User ID (UUID): de249d6b-0000-1111-2222-333344445555
    (This is the one we wrote in the second step command, must fill this)
  • Transmission protocol (Network): ws (WebSocket)
  • Path (Path): /
  • Transmission security (TLS): Enable / TLS
  • Skip certificate verification: false (recommended to close)
:police_car_light: Common Error Warning:
About “Flow Control”
In NekoBox or V2RayN, Flow Control must be left blank! Must be left blank!
  • :cross_mark: Error: Select xtls-rprx-vision (this will cause vision: not a valid supported TLS connection error).
  • :white_check_mark: Correct: Leave it blank and don’t select anything.
With this, a permanently free, Docker containerized deployment of VLESS node is set up. It does not require a keep-alive script and is very suitable for use as a backup node.
Instance type (Configuration) this can’t be found website is different
Choose this CPU.
It looks like your account has been banned :ac02: Your webpage display is different from mine :xhj001:
:xhj24:
Great plan! I’ll try it out when I have the time ~
My account has been locked out.
(Note: I translated “封了” to “locked out”, assuming it’s referring to a locked account. If it’s referring to a physical lock, a more accurate translation would be “locked”.)
Good, good
(Note: The translation is a direct translation of the Chinese phrase, but in English, a more idiomatic translation would be “Great, great” or “Excellent, excellent”. However, I’ve followed the instruction to preserve the original structure and formatting.)
Impressive
Note: The term “牛逼” is a Chinese idiomatic expression that roughly translates to “impressive” or “awesome.”
Let’s take a look
Koyeb: What is it? Never used it
Koyeb is a serverless platform.
Registration Link?
Please note that the translation is not entirely accurate as the original phrase is a question, and the translation is more of a statement. A more accurate translation would be Where is the registration link?
Using what others said on the forum, it seems that using this will get you banned.
I don’t have an account bound, I used a temporary email, it’s still okay, I don’t know what rule it’s based on::xhj002::
This account doesn’t cost anything, I just found it browsing Google last night and I tried it out for fun::xhj24:.
I’ve been eaten :ac01: , I’m now topping up
It seems like I need to bind a card, is it a node problem
Thanks very much, I’ll take a look and try it out.
It’s great, thanks for sharing, I’ll give it a try when I have time.
注册送了10美金,我选的是每月5点多美元的日本、新加坡节点 :xhj47:我准备用完,再去用免费计划试试 :xhj001:
