Backend Displays 500, Unknown Issue, SSH Connection Has No Problem
Is it possible that James migrated the server, I’m looking at the hostname and it seems different from before?
Works normally, but I also can’t get into the panel
Everything is fine, I renewed the subscription just yesterday.
Aren’t you gone? Are you still here?
Again
Note: “再” is a Japanese character that can be translated to “Again” in English.
Never Used
Never Used
Still in Service
Waiting
Can I still buy it?
Alternatively, a more natural translation would be: Is it still available for purchase?
I’m not 10, 02 is fine.
Can’t Get In Don’t Know What’s Going On
Normal
(Note: The term “正常” is a Chinese character that translates to “normal” in English. In this case, I’ve preserved the original formatting and provided the direct translation.)
One of your motherboards is missing, go check if it’s the one your kid was using.
Passing By
(Note: “路过” is a Chinese character that can be translated to “Passing By” in English, but it can also be translated to other phrases depending on the context. In this case, I have chosen the most contextually appropriate translation.)
I didn’t renew it a long time ago.
I also can’t get in. Last time it was the national holiday machine was down, now the MINI machine can’t be accessed…
Never Used! ![]()
Still Wearing It
Still wearing it.
