Free trial of Google AI Pro for 4 months, 3 devices
g.co/g1referral/278CULG4
Thanks for sharing the intel.
Previously, I’ve picked up some, if you need any, feel free to team up.
Join In
Note: The translation of ““参与一下”” is a common Chinese phrase that can be translated to “Join In” in English.
Thanks for sharing intel. :xhj14:
Thanks for not crashing
(Note: “没卡” is a Chinese idiom that means “not crashing” or “running smoothly”, often used to express gratitude when something works as expected.)
Thank you for sharing
Thank you for sharing Do you need to bind a card?
Virtual card is fine, I assume the pp external area is also okay.
Get a Card in Order
Get a card in order
Just taking a look, thanks
Note: I’ve kept the original Markdown formatting as it was.
Avalanche Block won’t let me pass.
Still Passed: It seems I still passed.
Congratulations, can’t you just leave me alone?
Thanks for sharing, go check it out.
Charge Ahead
Note: “冲冲冲” is a Chinese phrase that roughly translates to “Charge Ahead” in English, often used in a motivational or energetic context.
Thanks :ac08:
I don’t have enough information to provide a correct translation. The text “我那裡1個月免沒4個月” seems to be in a non-standard or colloquial Chinese dialect. However, I can try to provide a possible translation based on the characters:
“我那裡1個月免沒4個月” could be translated to “I haven’t been there for 1 month, not 4 months.”
However, this is not a standard or formal translation. If you could provide more context or clarify the dialect, I may be able to provide a more accurate translation.
Translation:
