Thanks for your contribution ![]()
Note: The emoji
is not translated as it is a custom emoji and not a standard Unicode character.
Note: The emoji
Arrived
(Transliteration of “” from Chinese)
Thank you
This year secondary domains have proliferated.
Support the Big Brother
(Note: The term “大佬” is a Chinese internet slang that roughly translates to “big brother” or “support the big brother”, but its meaning can vary depending on the context. In this case, I’ve chosen the most contextually appropriate translation.)
High-Quality Item from a Renowned Seller
Note: The original text is a Chinese idiom, and the translation is a direct translation of its meaning.
Thank you for sharing
I’ll take a look
Juste
Look, thanks
Support
Glance
(Note: The term “瞅瞅” is a Chinese idiom that roughly translates to “glance” or “take a look”. It is often used to express curiosity or interest.)
Check it out, and sign up while you’re at it! Thanks for sharing
Check it out. Big deal guaranteed to be a high-quality product! ![]()
Support
Mooing!!!
Thanks for sharing!
(Note: I’ve kept the original formatting and added a simple translation of the text. The term “大佬” is a Chinese term that roughly translates to “big shot” or “influencer”, but I’ve used a more general translation to preserve the original meaning.)
Big Brother is Really Strong ![]()
Take a look at this
Note: The translation of “看看这么个事” is a bit idiomatic and can be translated to “Take a look at this” or “Check this out”, but the most direct translation is “Look at this thing”. However, to preserve the original structure and formatting, I have chosen the more concise translation “Take a look at this”.
Sending you a thumbs up
(Note: The translation of “” is a common idiomatic expression in Chinese that means “giving someone a thumbs up” or “showing appreciation”. The translated text is a more direct and literal translation of the original phrase.)
