Free hosting, free renewal, automatic keep-alive
Free host address: https://dashboard.katabump.com/auth/login
Project address: GitHub - eishare/Singbox-nodejs
  1. Email registration
  2. Purchase server, name随意, choose nodejs, create service, wait patiently for one minute
  3. Access server, use Notepad to record the link, identifier, and password. Click to go to the server,
  4. Click Manage Server, find Network on the left, copy the port
Click Files, create a file
  1. Click Project address, select index.js, copy the following content, then copy the filename
  2. Create another file, copy the content of the second file, then copy the filename
  3. Create a third file, choose the third file, follow the above operations. Modify line five to change the port
  4. Click Terminal Management, start the service
Delay 220ms, barely able to watch 4K, purity 7%, located in France
  1. Keep alive
    Update once every four days, cannot be automatically updated by script, don’t forget to update.
  2. Keep alive
    This script automatically restarts at 3 AM Beijing Time, another way is through scheduled tasks to automatically restart
    Click to create task, name随意, click to edit and create a new schedule, restart every 5 minutes
Thank you for sharing!
Is this a container? Thanks for sharing.
Basically just a container, use it to play around and practice.
Thank you for sharing Will it take not more than a few days?
Thank you for sharing the container!
I am 83% extreme risk
Free rider gurus have arrived.
Thank you for sharing.
Renew every 4 days, let it be.
very detailed tutorial
Thanks for sharing
Thank you for sharing sourceMappingURL
This has been played before, setting up nodes to block.
Previously there was also Canada
Can it run Docker?
Wrote a script to automatically reboot daily
Little Nezha
Does it need to be renewed every 4 days?
