Freely Use ChatGPT Teacher Edition, No EDU Email Required, Valid for 3 Years
1、Access URL: https://chatgpt.com/k12-verification Click on [Verify Identity], normally it will redirect to SheerID verification
2、Then Telegram: https://t.me/auto_sheerid_bot?start=1999120066
3、Send the URL from the SheerID verification in your browser to the bot: /verify2 + URL (without the plus sign)
For example: /verify2 https://services.sheerid.com/verify/67c8c14f5f17a83b745e3f82/?verificationId=6928f0a5dcd9d851233a8959
Wait for a moment until the bot replies with success!
QQ_1764936264873
4、Wait approximately 10-20 minutes, then revisit the SheerID verification URL in your browser, as shown in the image, it should be basically OK! You need to wait for the bot’s verification email! (If it asks to submit additional documents, it’s basically over! This GPT account cannot be applied for again!)
5、After some time, revisit the address: https://chatgpt.com/k12-verification, you can join others’ spaces in your school or create your own space!
6、Fill in the space name and click continue to enjoy it!
This robot was apparently done by @pastking master
Is he just hiding it deeply without releasing it? :xhj001:
Did not directly send the robot address, I linked the channel, and do not wantto引流.
Thank you for sharing
I’ll help you send the robot, I’ll definitely bring some AFF :xhj18:
How successful was the verification rate? I tried two accounts and both failed.
There’s such a scandalous move..
Applying
Tested 2 accounts with different IPs and browsers, all failed.
Applied for two and both failed :ac01:
I successfully created a us+pp.ua domain email, but the review took almost a day, and today it was approved :xhj21:
Amazing! Give it a try.
Gemiin haven’t tried it, afraid it might cause an account ban. Previously, I felt that GPT5.1 Teacher Edition was enough (by the way, how long can K12 use it)?
Applying
Add that the submission form can submit several pure white images to fail the submission, reset the authentication status, and then allow the account to continue with the authentication process
Thank you for sharing, someone posted it already
Not bad not bad, freeloading is fun
So amazing Directly three years?
Can you provide more details, such as which IP registration and email are needed?
