Forum console exploded?
As stated, GO TO SERVER and console.nodeloc.com are down in freex\n
\n\n@moderators
Should it have been a long time already? The machine is working normally, it exploded halfway through,续费没有问题的,就是控制台没了
The console is gone.
Has been like this for a few days, but the service can still be used normally.
General only recharges energy, does not operate inside
Hope to fix it, port forwarding and other features cannot be used.
Waiting for seniors
These 500 have been going on for so long! Check when they will be fixed.
It seems to have been going on for a while.
It hasn’t worked for quite some time, I can’t even use the port :xhj21:
It has been several days already~
