[情报] Found a free NAT(KVM) chicken, sign up gets you 1 cent, minimum monthly fee is 0.097 cents.
It’s Paused Now…
Official Website:
[reply]Official Website (No AFF)[/reply]
There are 3 regions: Canada, Germany, UK.
Choose the lowest option with no pre-installed system
128M/1G
CPI+IO+Bandwidth select lowest priority
0.000135$/hour approximately 0.097$ monthly
Choose pre-installed Debian 12
256M/3G
0.00029$/hour approximately 0.2$ monthly
You can also play email forwarding, database, etc.
Let’s take a look
Liked the UI designeated
look
来看看
看看
Take a look, thanks for sharing.
intelligence and
look
来看看
看一下
It seems there is no bonus :xhj001:
Sure, it’s there upon registration, just the 1Tokens in the top right corner, equal to 1刀.
研究过token怎么获得没
Sign up and get
check
有的注册就赠送1刀
mjj是牛逼的,直接给他搞封车了
It seems there is no port forwarding setup. Found a network manage instead.
来晚了,没机会了
