We hope to add a program installation feature, as it is PHP.
Thank you for sharing
Thank you very much for sharing
Self-installed install.php.
Yes~ Installation functionality is built-in already
This is related to the servers you deployed, for example, if the ping between your machine in Shanghai (host) and Tokyo is very high, it will not be reachable. The logic is based on the status code returned upon access, which will give you a specific error message if there is an error.
I am on the same machine!
Great~
Check if the website WAF prevents crawlers or robots from accessing, as we don’t have a browser identifier header here
Learn from the tutorial!
Recently using uptimerobot, seems okay, no need to deploy it myself.
