Some questions about virtual hosting
1、Virtual hosts support SSH login, but not username and password. For security reasons, we need to use SSH keys to log in.
How to generate SSH keys, I found this article online: https://www.racent.com/blog/320
How to use SSH keys, please ask AI by yourself.
SSH connection was successfully tested.
2、Where to upload the key?
Click your username in the top right corner of the backend.
Then click:
3、If you cannot log in via FTP, you can use port 22 and log in using SFTP. Of course, you will also need the above key.
SFTP login was successfully tested.
4、If some clients do not support the key format, you can convert it by yourself.
5、Backend supports one-click SSL installation.
Click your domain name.
6、If you need to install WordPress,
still click your domain name, and you will see:
If you have any questions, feel free to reply or send a private message.
Wish everyone a pleasant website building experience.
Thanks bro for summarizing the experience. Hope you can be more tolerant for anything I don’t understand. Newbies like me need this kind of thing :ac08:
SSH tested, no issues, can connect and use normally;
Can the background of the post be removed? It looks awkward.
Okay, I understand.
Take a screenshot to see. I don’t know what theme you are using.
I am using the default forum theme, so you have to adjust your phone’s brightness to see my posts clearly
FTP indeed cannot connect, SFTP+key can;
I took a screenshot that is dark, and your bright theme looks awkward. It doesn’t feel off with others though. This system background change doesn’t seem to take effect.
The default theme looks awkward for such a small community​:rofl:
thank you great guy
Truly awkwared
The host’s program has an issue, the background cannot be deleted. @James
We can replace it first because the left side of the background is a bit dark. I will handle the issues that cannot be deleted later.
ok, changed.
Thanks
Now much more comfortable
Not bad not bad, although it’s been set up for a while now\nthe VPS is more comfortable to use
Understood Still have one question Does the panel show for a month? And then disappear when it expires?
free renewal
