Today I don’t know why tg is always showing refreshing on both my phone and computer. Messages only update when I enter the group chat. I am not using the unlocked version on my computer, but the unlocked version on my phone. At first, I thought it was a decryption issue, but switching versions didn’t help. I will try changing the version in the afternoon and see if it works. I wonder if anyone else is experiencing the same issue.
No problems, everything is normal
never encountered
Logging out and logging in again should fix it.
I tried switching to another number instead, which feels like it’s the number issue.
It worked normally after I switched it.
normal
No problem, just normal. Try a different node.
haven’t joined TG
No problem, normal
No problem
Not clear Rarely on tg
No problem, everything is normal.
Everything is normal
No problem
It’s back to normal, I updated the package.
It’s fixed, I updated the package.
Completely no problem
normal
No problem whatsoever
