I just need to develop a refund function. The energy can be transferred first as collateral, and unused amounts can be returned. ![]()
Good idea, check TG ![]()
Boss Strong! Admire the boss!
This is not bad
It feels like there is room for optimization. If it’s for a release node type, it’s not very convenient to operate. It’s suggested to add custom inventory quantities, and the content doesn’t necessarily have to be divided by rows
Amazing
It really worked impressive
Checked and the inventory is added, thanks pastking sir
Try it out, not bad
support this
The login API for the community seems to have changed
Oh oh, the original login server you used has been replaced with a new one. I thought you all had switched. https://www.nodeloc.com/oauth-provider/applications
How do you use the new server during login redirection? It seems the visitor is powerless.
Need @pastking guru to update Oauth2 information
OK, delayed more
Update complete, please kick me, thank you very much
Now http502
See what I have to sell
look behind to see an open-sourced personally built one
