Where is your ae.kg hosted
Which DNS hosts can add more than two ns records for this domain
hostry.com
1984 he.net Either of these will work.
However, I am using the built-in one because I need to bind it to its own virtual host for SSL verification.
he.net has 5 NS records, but I can only add two
Mine hasn’t been hosted yet.\n\nI wonder if it can be hosted on deSEC
You can host two as well, as long as the servers you fill in are normal, they will automatically sync all servers.
Write them two就行了
okayokay
DNS.NET.HE
Works anyway…
https://numbergenerator.org/pick2randomnumbers#!numbers=2&low=1&high=5&unique=true&csv=&oddeven=&oddqty=0&sorted=false&addfilters
You can pick two random numbers here then nsX.he.net :xhj09:
I just joined 1, 2 already, but I’m still unable to join he.net. I’ll try again later.
I used he as well but it didn’t work after waiting for several hours, now I’m using hostry instead
Two are enough, not five.
Hosted at free.kevsrv.me, use this virtual chicken to set up a small website directly for the domain.
ns1.ksapp.me
ns2.ksapp.me
gcore
gcore hosting shows this what does it mean
Data validation error, please check the data you provided.
error: parent zone is already occupied by another client
Users have added the root domain, so gcore will not verify the domain. Therefore, we need to wait for gcore to pull the PSL. I contacted the customer service.
You can add two more anyway I only added two
hostry吧
