Are you sure this is a public IP, hahaha
Yes I access FlyCow directly remotely
Is his public IP the same as the one obtained when linking to the Tower server?
I didn’t see clearly, thought it was the address bar instead, scared me for a moment
This seems rather ordinary, but when bt connects to other machines, it might include external IP information in the feedback.
No matter the reason, this immediately proves that bt will record server IP addresses. Privacy protocols are just a bunch of crap.
This… I’ll take a look!
urban records
buzhi don’t know how to share data with others with your public IP, how does your upload come from?
I locally built the bt and it didn’t use the public network; it obtained by itself.
Read the network card configuration
(Note that Tower cannot read IPv6, and pure IPv6 addresses display as 127.0.0.1)
Did哥come?
Retrieved from external API
Taishan has an international version, right? I haven’t used it so I don’t know much about it. As long as you connect to the network, there is no privacy.
Port connected to the internet, should it be able to get access normally?
There are public IP addresses, jealous
The left side is the public network. 192 is not.
This topic was automatically closed 24 hours after the last reply. No new replies are allowed.
