HuRong releases new "Power Uninstaller" Beta tool
The Huorong Security Team has released a new “Huorong Strong Uninstaller” Beta version software aimed at internet PC terminals. It focuses on being lightweight, simple, and dedicated, designed to solve the issues of incomplete uninstallation and complex operations of traditional uninstallation tools, providing users with more thorough software removal capabilities and a cleaner system environment. According to the official introduction, this tool has a small size and low resource consumption, supporting Windows 7, 8/8.1, 10, 11, and Windows Server 2008 R2 and above versions. It can record software installation behavior in real-time and precisely clear files, registry entries, and associated components during uninstallation.
Official提示:当前版本的删除文件操作可能存在风险,建议优先在虚拟环境中试用。
Huorong Security Software
The installation package is quite small.
Thank you for sharing
Thank you for sharing, will this need to be monitored in the background for the long term? Will it affect performance?
They say it’s resource-intensive, but it’s still just a beta version, so let’s observe for now :xhj14:
I use Fenghuang instead
I’ll give it a try
Do you want to uninstall the tool?
security tools
Can other security software be uninstalled without a password?
This antivirus software is ad-free and良心无广告 haha
Lightweight tools, give them a try
Strong Uninstaller This is good
Thank you for sharing, better to try it out after it’s more refined.
