indevs.in subdomain SSL certificate has issues
Cloudflare cannot issue an SSL certificate for this domain, only the backup certificate was issued, but it cannot be used
Test website
Everything is fine, you just need to wait half an hour.
Okay, I will check later
It will be okay in a moment, or delete and regenerate if not.
What is the problem
This one was deleted previously, so it’s not registered as l.e
I didn’t apply when it came out previously because I heard they stopped registering the day after, missed it!
Its certificate is a bit slow
Now you can register, Github direct login, essentially it’s checking your main Github email.
Thanks for the reminder I thought registration was closed!
