which AI programming tool can customize third-party models
Which AI programming tool can customize third-party models :xhj11:
omnipotent mjj们
claudecode
trae can connect to popular third-party vendors, but to integrate an openai-format custom base URL, you need to use the MTGA project on GitHub. I often use the Claude from the charity station to achieve this.
Understand better
Understood understood
Used little No suggestions
I look see
