ShareNL:Users of HZSG with ISIF nodes please note
Good news, I have updated my script so that docker can now be used completely normally.\n\nBut since I currently only have SSH access to the HZSG母机 server, this feature is currently only available for containers using the HZSG节点.\n\nYou need to restart your containers, and then you can use docker normally.\n\nPlease wait for Lao Zhan to synchronize the remaining servers.
Too bad there isn’t啊
Congratulations on having this dick
want a dick
Yo yo yo, finally.
Missed :xhj14:
isif Old Zhan has synchronized already, go try it fast
Sorry not to
Unfortunately there isn’t Asking what Docker’s functionality is
acknowledged
Thanks
Received Great!
I have isif, try it out
ShareNL’s machines aren’t supposed to be able to be restarted otherwise they will become unresponsive? Er… not sure if it’s the panel restart or reinstallation..
Reinstalling doesn’t work, but a reboot does. Or you can just execute reboot.
Oh, just that you can’t reinstall it, it’s a small thing.\nWorst case, delete it and reinstall it again.
But you can use scripts; this is just a panel bug :xhj16:
I found that no one has mentioned this issue yet, so I’ll bring it up…
isif I failed here… The issue persists.
Connecting to host...
Connection successful
Last login: Sun Jan 11 18:30:28 2026 from 10.156.238.1
root@isif-9471:~# reboot
Connection lost
Last login: Sun Jan 11 18:34:39 2026 from 10.156.238.1
root@isif-9471:~# cd alpine
root@isif-9471:~/alpine# ls
data  docker-compose.yaml
root@isif-9471:~/alpine# cat docker-compose.yaml
services:
  alpine-container:
    image: alpine:latest
    container_name: alpine
    # network_mode: host
    ports:
      - "10031:22"
      - "10032:10032"
    tty: true
    stdin_open: true
    environment:
      TZ: "Asia/Shanghai"
    volumes:
      - ./data:/data
    restart: always
root@isif-9471:~/alpine# docker compose up -d
WARN[0000] No services to build
[+] Up 1/1
 ✔ Container alpine Created        0.2s
Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: open sysctl net.ipv4.ip_unprivileged_port_start file: reopen fd 3: permission denied
Thanks, hope to get detailed steps, thanks
hzsg I here is no problem, I will check what the issue is later isif.
