How to delete the ccwu.cc domain name
Can the domain name ccwu.cc with the .cc suffix created on dnshe website be deleted?
Sure, I heard you can raise a ticket to delete it.
Raise ticket to delete
Only work orders can be deleted or gifted. Let’s see if it can be gifted.
look
Can transfer it to me
Can CF Not
Currently, the panel cannot be deleted. Delete functionality will be added later.
Click on the details, if there’s a delete button you can delete it. If you cannot delete it, you can register another account and transfer the domain away.
haven’t deleted it, learn about it
Give it to someone else!
Increase and Distribute
Write your domain name, attach a referral code, and write that the domain has permanent rights. Post it on the forum, and I think someone will take it up. It will be processed faster than through a ticket.
Currently cannot delete, but can transfer
Cannot delete, but should be able to push
I raised a ticket to delete it
Try contacting the support ticket, should work.
Did the quota become empty after the transfer?
Not needed, just throw it into the forum, someone might want it.
Yes, your quota will be released once the other party successfully receives it.
Summary
dnshe.com注销域名的操作方式
两种情况:
  1. 域名未添加过任何解析
    可以在控制面板自助删除.
  2. 已有过添加解析的操作
    不可自助删除. 只有两条路
    1. 新注册个账号转移给它(不推荐, 指不定什么时候因为滥用太高搞连坐)或者扔给其他人, 对方成功接收后占用他的域名额度那么你的域名额度就释放出来了
    1. 发工单请求人工删除(别跟那个机器人聊, 他没有权限的. 开启工单了直接回复人工, 然后静静的人工处理)
      PS: 如果你没有托管到其他DNS服务商, 直接使用他家的域名解析务必备份一下解析记录.(因为他可能会误删…)
