Because I always use Bing to search, I recently found that after searching, the pages would freeze and become unclickable, with a timeout prompt saying the page was non-responsive after 10-30 seconds. This issue didn’t exist before and only appears on my work tablet. Recalling what happened, two days ago there was a Windows update, and I manually updated it (since I have original genuine Home Edition). It seems the update caused some issues…emm, it’s driving me crazy…
Don’t understand
I did not use this
I also like updating the latest version
Using Chrome, Edge also uses the Chrome内核, which is slightly inferior in performance and processing compared to Chrome. If you like Edge’s features, you can use Google search.
It’s probably due to a bug in Edge itself and should not be related to Windows Update… Edge has its own independent automatic update channel…
Next month when Edge pushes the update, it should be fixed. Edge’s bugs are really quite a few now.
So now we just use Chrome directly
This hasn’t been a problem much, I mostly use the Chrome browser, and Edge is just a backup.
I have been experiencing this lately, too; Edge will occasionally freeze up.
Awkward~
didn’t really feel it
Did you use any user script?
Fixed a BUG where the system was too smooth
Basic never updates
Redo the system吧
First remove all extensions, the most likely culprit is antivirus protection.
It’s the same even after moving to another district, switching to Google Chrome would be better, also confusing.
Got bugs??
Edge bugs too many, I switched to Firefox
Never encountered it~
