Made an online image toolbox
imgexe.com — Free Online Image Toolbox
No registration required, no installation needed, just open your browser to use.
Address: https://imgexe.com
What Tools Are Included?
Tool Description
Image Compression Drag and compress, supports batch processing, significantly reduces file size
Format Conversion Convert between JPG / PNG / WEBP / GIF
Image Cropping Free cropping, supports aspect ratio locking
Image Mosaic Combine multiple images into one long image, one-click export
Puzzle/Grid Multiple layout templates, supports custom grid division, add text/arrows/annotations
Image Splitting Divide one image into N equal parts
Add Watermark Text watermark, supports custom position, transparency, and rotation
Remove Watermark AI intelligent repair, automatically fills painted areas
Features
  • Completely Free, no ads, no forced login
  • Privacy Security, images are processed locally in the browser (compression/cropping/mosaic), not uploaded to servers
  • Simple interface, intuitive operation, usable on mobile devices
Welcome to bookmark this for future use, you might find it handy when handling images. Any issues or suggestions, feel free to leave a comment.
Thank you for sharing
Too advanced, thank you for sharing
Thank you for sharing, support great tools
looks very advanced
Suggest adding support for uploading images with CTRL+V
support大佬
Great tool
:ac01: Came
It looks good, the interface has a very sophisticated feel
Come get a red envelope
thank you
Not bad, thanks for the friend’s share.
good
Thank you for sharing, but for mobile adaptation, the middle operation area is narrow while the side buttons are wide.
