n/programu/runoneall · 8 个月前
n/program · 8 个月前 · 已编辑 · 442 次浏览
u/runoneall王者
我制作了一个伪 DNL 的 whois 服务器
起因是,我把 whois.rr.kg 这个域名抢了,然后打算写点什么...
成品展示:https://whois.rr.kg/
服务跑在 Serv00 上
源代码:
import express from "express";
import ejs from "ejs";
const app = express();
app.engine("ejstxt", ejs.renderFile);
app.set("view engine", "ejstxt");
app.use(express.static("public"));
app.get("/:domain", async (req, res) => {
  const domain = req.params.domain;
  const whoisServer = "https://domain.nodeloc.com/api/public/whois/";
  const currentHost = req.get("host");
  res.header("Content-Type", "text/plain; charset=utf-8");
  try {
    const resp = await fetch(whoisServer + domain);
    const data = await resp.json();
    if (data.error) {
      return res.status(400).send(`Error: ${data.error}`);
    res.render("template.ejstxt", {
      data: data,
      host: currentHost,
      timestamp: new Date().toISOString(),
  } catch (error) {
    console.error(error);
    res.status(500).send("Internal Server Error");
app.listen(3000, () => console.log("Server started"));
Domain Name: <%= data.full_domain || "N/A" %>
Registry Domain ID: NOT_APPLICABLE
Registrar WHOIS Server: <%= host %>
Registrar URL: https://domain.nodeloc.com
Updated Date: <%= data.registered_at || "N/A" %>
Creation Date: <%= data.registered_at || "N/A" %>
Registry Expiry Date: <%= data.expires_at || "N/A" %>
Registrar: Nodeloc Free Domain
Registrar IANA ID: Not Provided
Domain Status: <%= data.status || "inactive" %> (https://icann.org/epp#<%= data.status || "inactive" %>)
Registry Registrant ID: REDACTED_FOR_PRIVACY
Registrant Name: REDACTED_FOR_PRIVACY
Registrant Organization: REDACTED_FOR_PRIVACY
<% if (data.nameservers && data.nameservers.length > 0) { -%>
<% data.nameservers.forEach(ns => { -%>
Name Server: <%= ns %>
<% } else { -%>
Name Server: Not Provided
DNSSEC: unsigned
### Additional System Metadata ###
Days Until Deletion: <%= data.days_until_deletion ?? "null" %>
Days Until Suspension: <%= data.days_until_suspension ?? "null" %>
First Failed At: <%= data.first_failed_at ?? "null" %>
Suspension Reason: <%= data.suspend_reason ?? "null" %>
Suspended At: <%= data.suspended_at ?? "null" %>
### Health & Scan Reports ###
<% if (data.scan) { -%>
Overall Health: <%= data.scan.overall_health || "N/A" %>
DNS Status: <%= data.scan.dns_status || "N/A" %>
HTTP Status: <%= data.scan.http_status || "N/A" %>
SSL Status: <%= data.scan.ssl_status || "N/A" %>
Safe Browsing: <%= data.scan.safe_browsing_status || "N/A" %>
VirusTotal: <%= data.scan.virustotal_status || "N/A" %>
Uptime: <%= data.scan.uptime_percentage ? data.scan.uptime_percentage.toFixed(2) + "%" : "N/A" %>
Last Scanned: <%= data.scan.last_scanned_at || "N/A" %>
<% } else { -%>
Scan Status: No scan data available
>>> Last update of WHOIS database: <%= timestamp %> <<<
6
16
16 条回复
  1. cs9u 钻石 钻石会员 8 个月前
    ch查不到呢
  2. runoneall 王者 楼主 8 个月前
    哪个域名?我用的是官方的 api,有一些很特殊的域名似乎就是查不到
  3. runoneall 王者 楼主 8 个月前 已编辑
    https://whois.rr.kg/domain/ch.loc.cc
    应该是这个吧,可以查到的
  4. cs9u 钻石 钻石会员 8 个月前
    是我没有仔细看,原来只能查loc.cc的二级域名。
    是说我查.163.com查不到哦。
  5. runoneall 王者 楼主 8 个月前 已编辑
    因为是 DNL 的 whois 服务器()
  6. bashell 钻石 8 个月前
    膜拜大佬
  7. Serendipity1 钻石 8 个月前
    厉害厉害
  8. Seraphina 钻石 8 个月前
    :xhj003: 赞啊
  9. hakd 王者 2 YEARS 8 个月前
    这页面真是返璞归真啊,直击痛点
  10. qiang 白银 8 个月前
    不错的内容,Mark
  11. lovoup 钻石 3 YEARS 8 个月前
  12. James 💯 传奇 MANAGER 8 个月前
    @imgload 呆哥也弄了一个的。
  13. imgload 白银 大神 8 个月前
    :ac01:再给坛友分享一下脚本https://www.nodeloc.com/t/topic/78335
    支持查询国际互联网1500+域名后缀与.loc.cc后缀
  14. runoneall 王者 楼主 8 个月前
    这个真支持,发现好东西了
  15. dj56959566 黄金 不离不弃 8 个月前
    感谢分享!
  16. semilas 黄金 8 个月前
    必须支持,赞
