Total Time : 9 min 48 sec
Huh?
I’m not sure if it’s my network issue, but every time I connect directly, there’s a 60% failure rate. It feels like I can sometimes get through for a bit, but then it drops again.
us2109431xxx:~# fastfetch
.hddddddddddddddddddddddh. root@us2109431xxx
:dddddddddddddddddddddddddd: -----------------
/dddddddddddddddddddddddddddd/ OS: Alpine Linux v3.22 x86_64
+dddddddddddddddddddddddddddddd+ Host: KVM (RHEL 7.6.0 PC (i440FX + PIIX, 1996))
`sdddddddddddddddddddddddddddddddds` Kernel: Linux 6.8.0-107-generic
`ydddddddddddd++hdddddddddddddddddddy` Uptime: 17 hours, 16 mins
.hddddddddddd+` `+ddddh:-sdddddddddddh. Packages: 69 (apk)
hdddddddddd+` `+y: .sddddddddddh Shell: sh
ddddddddh+` `//` `.` -sddddddddd Display (VGA-1): 1024x768 [External]
ddddddh+` `/hddh/` `:s- -sddddddd Terminal: /dev/pts/1
ddddh+` `/+/dddddh/` `+s- -sddddd CPU: Intel(R) Xeon(R) E5-2696 v4 @ 2.20 GHz
ddd+` `/o` :dddddddh/` `oy- .yddd GPU: Cirrus Logic GD 5446
hdddyo+ohddyosdddddddddho+oydddy++ohdddh Memory: 17.07 MiB / 122.07 MiB (14%)
.hddddddddddddddddddddddddddddddddddddh. Swap: Disabled
`yddddddddddddddddddddddddddddddddddy` Disk (/): 13.51 GiB / 50.00 GiB (27%) - btrfs
`sdddddddddddddddddddddddddddddddds` Local IP (eth0): 10.231.235.xxx/24
+dddddddddddddddddddddddddddddd+ Locale: C.UTF-8
Originally, I wanted to install Debian 13, but after switching systems, it wouldn’t boot. Opened a support ticket and was told the disk space doesn’t support Debian 13, so I have to use Alpine.
But hey, this thing gives you 10 years in one go—I gotta say, the boss is really generous!!!
Thanks for sharing your review!
It’s free, what more do you want?
128MB of memory is too small for Debian. After installing Debian, a few ports were inaccessible, so I switched back. So far, I haven’t noticed any connection issues. The bandwidth doesn’t seem very high—YouTube speeds are just over 10,000 (Kbps), using China Telecom.
Sure, can the hard drive fit one script?
Thank you for the review
There’s a 3.5-yuan one, seems decent enough as a backup phone.
Thank you for sharing the review results.
