Who said the forum’s virtual host was gone? It’s back now!
Currently, only vmiss is available
Application link: https://hosting.nodeloc.com
Once your application is approved, login information will be sent to the email address linked to your forum account.
Only available to users with Silver level or above
Panel login address: https://vmiss.nodeloc.com/
There are only 160 spots available, first come, first served.
Thank you, Your Excellency
This is amazing—it finally solved a stubborn problem I’ve struggled with for years.
Take a look, give it a try
Here we go, let’s try creating one.
What about before that? I think I also chose this one before, but I’ve totally forgotten which domain I linked, haha.
Deleted everything. CyperPanel is nothing but trouble.
Crap, I totally forgot which domains were bound. Some of the ones I kept alive probably got quietly deleted and I don’t even remember which ones :ac01:
Nice :+1:
Managed to snag one smoothly, thanks bro!
VMISS’s connections are really awesome.
Domain selection shows NO DATA
It will fetch data from domain.nodeloc.com. Only registered domains that are active can apply for hosting.
Awesome
Come take a look
After creation, what are the username and password for logging into the panel?
They’ll send an email—check the inbox of the email you have linked to your nodeloc account.
mail.nodeloc.com I have no idea what the email and password are here either. Where was it registered? Where was it linked?
The email you used to register your nodeloc account.
OK, got it.
