Claude Platform now live on AWS! Use Anthropic's native platform and your AWS account all in one place
Claude Platform on AWS is Live! Native Anthropic Platform + Unified AWS Account Experience (Released May 11, 2026)
This means AWS users can now access Anthropic’s native Claude Platform directly using existing AWS credentials, IAM policies, and unified billing—enjoying the full feature set without needing to register a separate Anthropic account or manage multiple credentials.
Key Highlights
  • Native Claude Platform Experience: Full support for all Claude APIs, features, and the Console, including the latest beta functionalities, updated in sync with the Anthropic website.
  • Seamless AWS Integration:
    • Access via existing AWS IAM credentials (no extra API Key needed)
    • Audit logs fed directly into CloudTrail
    • Unified AWS billing (supports committed spend)
  • Available Models: Claude Opus 4.7, Sonnet 4.6, Haiku 4.5, with new models launched concurrently.
  • Available Regions: Most AWS commercial regions, with global and US-based inference support.
Powerful Native Features Included (Some in Beta)
  • Claude Managed Agents: Large-scale Agent deployment
  • Advisor strategy: Enhance Agent intelligence with advisor models
  • Web Search + Web Fetch: Real-time access to the latest internet information
  • Code Execution: Run Python code, generate charts, and analyze data directly via API
  • Files API: Upload documents and reference them in conversations
  • Skills: Train Claude on best practices for more consistent outputs
  • Prompt Caching: Dramatically reduce context repetition costs and latency
  • Citations, Batch Processing, MCP Connector, and more
You can also use the Claude Console (includes prompt optimizer, generator, and evaluation tools).
Claude Platform on AWS vs Claude on Amazon Bedrock (Important Comparison)
Dimension Claude Platform on AWS Claude on Amazon Bedrock
Operator Anthropic (native platform) AWS (managed)
Data Handling Handled by Anthropic, data exits AWS Handled by AWS, data always stays within AWS
Feature Set All native features + beta in sync Bedrock specific features (Guardrails, Knowledge Bases, etc.)
Data Residency No strict requirements Suitable for strict data residency needs
Best Fit Full, cutting-edge Claude experience Prioritizes enterprise compliance and isolation
In summary:
  • If you want the most powerful, complete, and latest Claude native capabilities → choose Claude Platform on AWS.
  • If you have strict requirements for AWS-only data residency or need Bedrock enterprise features → stick with Bedrock.
Pricing
Identical to direct Claude API pricing, billed through AWS.
How to Get Started
  1. Visit the AWS Claude Platform Console
  2. Sign in with your existing AWS account
  3. Detailed documentation available from both AWS and Anthropic
Users with a Bedrock Private Offer should contact their Anthropic/AWS account manager to ensure discounts are appropriately applied (discounts cannot be retroactively applied).
This is an extremely developer-friendly new option: you benefit from AWS account management and billing convenience while getting the most comprehensive Anthropic platform capabilities.
Official links:
Related screenshots:
So thorough :rose: Thanks for sharing, it must have taken effort :rose:
Generated by AI, but the screenshot is real.
Newcomer here to learn :+1:
Learn a bit
Study, study.
Not sure what happens with account bans.
So how do I get it for free, bro?
What’s going on here? Can anyone help me out?
Just click to continue like this
Change the category from General Discussion to AI
Not all accounts are supported.
