Sharing a lightweight monitoring panel I use (great for low-memory/CT8 systems, supports automated workflows)
Title: Sharing My Personal Lightweight Monitoring Dashboard (Designed for Low RAM/CT8, Supports Automated Workflow Integration)
I used to rely on Uptime Kuma, but on some 512MB RAM machines or CT8/Serv00, it struggles to run smoothly and frequently gets killed by the system OOM in the background. Since I couldn’t find anything on the market that’s light enough and user-friendly, I decided to whip up my own with AI. The focus is on low resource usage, high customizability, and being maintenance-free. It’s now polished enough, so I’m open-sourcing it for everyone to use freely.
Project link: https://github.com/debbide/monitora
Key Features:
  1. Super lightweight: No MySQL or other heavy dependencies, powered purely by SQLite. Daily runtime memory usage is only around 150MB, so it runs perfectly on strict free hosts like CT8/Serv00.
  2. Advanced automation integration (for power users):
    The dashboard does more than just check service availability — every monitoring item supports deep customization for both Webhook Headers and Body.
    For example: You can monitor your own CF Tunnel domain, and if the panel detects the tunnel is down, it will instantly send a POST request with an auth token to the GitHub API, precisely triggering a GitHub Actions workflow to restart your tunnel endpoint. This means you get a fully automated fault recovery loop!
  3. Anti-ban & Keep-alive Mechanisms: Many free hosting providers will suspend accounts for periodic scripts. The system supports “random interval scheduling”—for instance, you can set a task to trigger randomly every 10–12 days, perfectly simulating human activity, so you no longer get banned as a bot.
  4. Maintenance-free cloud backups: Supports scheduled full backups to WebDAV or Telegram. Built-in 7-day rolling overwrite logic so you don’t have to worry about clogging up your cloud storage.
  5. Smart database slimming: Every night, redundant monitoring point data is auto-cleaned and SQLite undergoes physical compression. The data is ready to use as a single file that you can copy anywhere—a perfectionist’s dream.
How to Deploy:
CT8 / Serv00 Users (one-click lossless install/upgrade script):
curl -sL "https://github.com/cokear/gtool-releases/raw/refs/heads/main/install_monitora.sh?v=$(date +%s)" | tr -d '\r' > install_monitora.sh && bash install_monitora.sh
Go taste it right away to check if it’s salty enough.
Awesome skills, thank you for sharing!
This project seems really nice—might as well give it a try instead of just letting it collect dust. Is there any chance for Cloudflare support?
If it were ported for deployment on CF, many features would have to be cut. If there’s enough demand, we can have AI give it a try.
Thanks for sharing
Is there a video tutorial? Reading the text is making my brain hurt.
Just passing by, thought I’d take a look.
This is really good! :+1::+1::+1:
Thanks for sharing!!
One-click setup is quick and convenient — now I’m using one built with serv00 :xhj003:
A6, you’re awesome!
Thanks for sharing, I’ll give it a try and see how it works.
Set this topic as recommended and awarded 200 energy
This post of yours would really shine out there!
Niunium, did you quit the internet? My navigation can now also be deployed on ct8.
Will installing ct8 delete my account?
Nice
This is great, thanks for sharing.
Take a look
