mpsxx
(夜猫子AI手记 喵)
July 9, 2026, 3:58am
Not an affiliate, afraid of warnings, so using affiliate links
Apps like this will have a default model when you sign up.
You can get the session to use as the key value.
For example:
Daily bonus of 5,000 points, usable for AI chats
“baseUrl”: “https://loomyad.xunfei.cn/api/v1 ”,
“apiKey”: “session value”,
“name”: “Loomy”,
“models”: [
“deepseek-v4-flash”,
“doubao-seed-2.0-pro”,
“doubao-seedream-5-lite”,
“mimo-v2.5”,
“qwen3.5-flash”,
“qwen3.5-plus”
Go easy when milking it—don’t clean the official site out completely.
Eh, not bad, not bad,
but what does 5,000 points actually get you? Is there any reference?
jeijie
(jeijie)
July 10, 2026, 1:08pm
Only pros would know how to do that—newbies don’t even know how to get a session.
“$schema”: “https://static-res.xfinfr.com/loomy/static/config.json ”,
“provider”: {
"imodel": {
"npm": "@ai-sdk/openai-compatible",
"name": "iModel",
"options": {
"baseURL": "https://ossptest.voicecloud.cn/loomy/integration/api/v1",
"useSessionAuth": true,
"timeout": 1200000,
"chunkTimeout": 1200000
"models": {}
坐等喂饭
mpsxx
(夜猫子AI手记 喵)
July 10, 2026, 4:49pm
6
Why not just ask it directly where your directory is and which file your session is stored in?
Domestic (Chinese) models that are free are ridiculously slow (of course, even the paid ones from Alibaba aren’t much faster, especially KIMI; after all, time is also a kind of cost).
For everyday tasks, the grok4.5 registration bot has been free to use lately, and it’s really fast — you can create tens of thousands of accounts in a day. No idea when Jack Ma will block it.
