n/aiu/uefi2331 · 4 个月前
n/ai · 4 个月前 · 556 次浏览
u/uefi2331黄金
青龙自动化QwenPaw每日保活
【青龙面板】AgentScope QwenPaw 每日自动保活
原理
QwenPaw Console 长时间不打开会被回收,需要每天点一次"打开 QWENPAW"按钮保活。手动太累,用青龙 + Playwright 自动化完成任务。
两个脚本配合:
  • 登录脚本:每 20 天跑一次,登录 AgentScope 保存 localStorage(含 accessToken)
  • 保活脚本:每天跑一次,注入 localStorage → 打开 /deploy → 自动点击按钮
一、依赖
青龙面板 → 依赖管理 → Python,添加:
playwright
SSH 进容器装 Chromium:
docker exec -it qinglong bash
pip install playwright
playwright install chromium
playwright install-deps
二、环境变量
青龙 → 环境变量:
名称 值
AGENTSCOPE_EMAIL 你的AgentScope登录邮箱
AGENTSCOPE_PASSWORD 你的AgentScope密码
AGENTSCOPE_AUTH_FILE /ql/data/scripts/auth/agentscope_auth.json
三、脚本
先建目录:
mkdir -p /ql/data/scripts/auth
脚本1:agentscope_login.py
青龙 → 脚本管理 → 新建文件 agentscope_login.py:
#!/usr/bin/env python3
"""AgentScope 登录刷新 — 每20天执行,保存 localStorage"""
import asyncio, json, os, sys
from playwright.async_api import async_playwright
EMAIL = os.environ.get("AGENTSCOPE_EMAIL", "")
PASSWORD = os.environ.get("AGENTSCOPE_PASSWORD", "")
AUTH_FILE = os.environ.get("AGENTSCOPE_AUTH_FILE", "/ql/data/scripts/auth/agentscope_auth.json")
SCREENSHOT_DIR = os.path.dirname(AUTH_FILE)
UA = "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/125.0.0.0 Safari/537.36"
async def login():
    print("[登录] 启动浏览器...")
    async with async_playwright() as p:
        browser = await p.chromium.launch(headless=True, args=["--no-sandbox", "--disable-blink-features=AutomationControlled"])
        context = await browser.new_context(viewport={"width": 1920, "height": 1080}, locale="zh-CN", user_agent=UA)
        await context.add_init_script("Object.defineProperty(navigator, 'webdriver', {get: () => undefined});")
        page = await context.new_page()
        print("[登录] 打开登录页...")
        await page.goto("https://platform.agentscope.io/login", timeout=30000)
        await page.wait_for_load_state("networkidle", timeout=15000)
        await page.wait_for_timeout(5000)
        await page.fill("#account", EMAIL)
        await page.fill("#password", PASSWORD)
        btn = await page.query_selector('button:has-text("登 录")') or await page.query_selector('button:has-text("登录")')
        if not btn:
            print("[登录] ✗ 未找到登录按钮")
            await browser.close()
            return False
        await btn.click()
        if "login" in page.url.lower():
            print("[登录] ✗ 仍在登录页")
            await page.screenshot(path=f"{SCREENSHOT_DIR}/login_failed.png")
            return False
        ls_data = await page.evaluate("""() => {
            const data = {};
            for (let i = 0; i < localStorage.length; i++) {
                data[localStorage.key(i)] = localStorage.getItem(localStorage.key(i));
            return data;
        os.makedirs(os.path.dirname(AUTH_FILE), exist_ok=True)
        with open(AUTH_FILE, "w") as f:
            json.dump(ls_data, f, indent=2)
        print(f"[登录] ✅ localStorage 已保存 ({len(ls_data)} 个 key)")
        await page.screenshot(path=f"{SCREENSHOT_DIR}/login_success.png")
        return True
if __name__ == "__main__":
    r = asyncio.run(login())
    print(f"\n{'✅ 登录成功' if r else '❌ 登录失败'}")
    sys.exit(0 if r else 1)
脚本2:agentscope_daily.py
"""AgentScope QwenPaw 每日保活 — 注入token → 点击按钮 → 验证Console"""
BASE_URL = "https://platform.agentscope.io"
async def relogin():
    """token过期时重新登录"""
    print("[保活] token 过期,重新登录...")
    from agentscope_login import login
    return await login()
async def daily():
    print("[保活] 启动浏览器...")
    if not os.path.exists(AUTH_FILE):
        print("[保活] 无 auth 文件,先登录...")
        return await relogin()
        # 先访问主页再注入
        await page.goto(BASE_URL + "/", timeout=30000)
        await page.wait_for_timeout(3000)
        with open(AUTH_FILE, "r") as f:
            ls_data = json.load(f)
        for k, v in ls_data.items():
            await page.evaluate(f"localStorage.setItem('{k}', '{v}')")
        print(f"[保活] 注入 {len(ls_data)} 个 key")
        # 跳转 deploy 页
        await page.goto(BASE_URL + "/deploy", timeout=30000)
        print(f"[保活] 当前: {page.url}")
        # 找按钮
        btn = await page.query_selector('button:has-text("打开 QWENPAW")')
        if not btn:
            btn = await page.query_selector('button:has-text("QwenPaw")')
        if not btn:
            btn = await page.query_selector('button:has-text("打开")')
        if not btn:
            body = await page.inner_text("body")
            print(f"[保活] ✗ 未找到按钮,页面: {body[:150]}")
            await page.screenshot(path=f"{SCREENSHOT_DIR}/daily_no_btn.png")
            return False
        print("[保活] 找到按钮,点击...")
        new_page_promise = context.wait_for_event("page", timeout=15000)
        await btn.click()
        try:
            new_page = await new_page_promise
            await new_page.wait_for_load_state("networkidle", timeout=20000)
            await new_page.wait_for_timeout(5000)
            title = await new_page.title()
            print(f"[保活] ✅ QwenPaw Console 打开成功!")
            print(f"  URL: {new_page.url}")
            print(f"  标题: {title}")
            await new_page.screenshot(path=f"{SCREENSHOT_DIR}/qwenpaw_daily.png")
            return True
        except Exception as e:
            print(f"[保活] ✗ 新标签异常: {e}")
            return False
    r = asyncio.run(daily())
    print(f"\n{'✅ 保活成功' if r else '❌ 保活失败'}")
四、配定时任务
青龙 → 定时任务 → 新建两条:
名称 命令 Cron 说明
AgentScope 登录刷新 task agentscope_login.py 0 8 */20 * * 每20天8点登录
QwenPaw 每日保活 task agentscope_daily.py 30 8 * * * 每天8:30保活
五、验证
先手动跑一次登录:
cd /ql/data/scripts && python3 agentscope_login.py
再手动跑一次保活:
python3 agentscope_daily.py
看到 ✅ QwenPaw Console 打开成功! 就成功了。
截图在 /ql/data/scripts/auth/ 下,有问题可以看截图排查。
9
20
20 条回复
  1. crazzzzzysnail 黄金 4 个月前
    并不需要这么麻烦,让ai写个检查ssh等环境的脚本,然后定时任务每天跑一下。已经快1个月都在线
  2. uefi2331 黄金 楼主 4 个月前
    还是佬厉害:xhj005:
  3. 8851982 黄金 4 个月前
    我也试试
  4. azhaoyihao 荣耀 水王 4 个月前
    已收藏保存💾
  5. lbj 铂金 3 YEARS 4 个月前
    真的就这么搞出来了。厉害
  6. uefi2331 黄金 楼主 4 个月前
    有佬分享过更简洁轻量的( :xhj10:
  7. tanmoumou252 黄金 4 个月前
    他登录界面都根本就不做人机校验的,你你还觉得这有难度啊
  8. Ning_liu 黄金 4 个月前
    懂哥来这个社区就是牛🖊️,到处锐评
  9. tanmoumou252 黄金 4 个月前
    这都被你发现了
  10. jzhfg 🍑富可敌国 王者 MANAGER 4 个月前
    这个是不是可以安装docker容器和长亭百智云相似吗?
  11. uefi2331 黄金 楼主 4 个月前
    貌似不支持docker,本身就是容器 :xhj001:
  12. jzhfg 🍑富可敌国 王者 MANAGER 4 个月前
    你拿来安装什么项目? :xhj33:
  13. uefi2331 黄金 楼主 4 个月前
    还在摸索中呢 :xhj007:
  14. 8851982 黄金 4 个月前
    试过了Docker可以安装,但无法运行
  15. ketto 🔥 铂金 3 YEARS 4 个月前
    这个非常不错,感谢大佬分享。
  16. berrice 黄金 不离不弃 4 个月前
    大佬厉害
  17. q120656387 黄金 4 个月前
    好东西,帮顶
  18. Helios 白银 4 个月前
    可以!大佬
  19. yifangovo 黄金 4 个月前
    好东西
  20. small_qiang 白银 4 个月前
    青龙很久没玩了
