As shown in the picture. The test speed is really impressive. The inference is blazing fast. ![]()
The new version of the UI also looks much better.
Go try it out!!! https://m365.cloud.microsoft/chat
(Now there’s a new reason to update to 2API!
Is it free? Can I use it without paying?
This reverse proxy tech guru should hurry up and push an update.
It’s pretty awkward that using a reverse proxy makes it impossible to call the tools.
It’s fine as long as it can be reverse-proxied ![]()
Hmmm, simply not adding stronger prompt constraints doesn’t really make it better, it’s not that it can’t be supported (though).
Wasn’t this a long time ago? Why is it being posted again now?
It seems like 5.6 just came out in the past couple of days.
It was available on the very day ChatGPT was released.
Well, I just noticed in the past couple of days that even the option to select GPT was gone for a few days before. I thought it was a bug and didn’t pay much attention to it.
Is reverse proxy okay?
I just checked, and mine is still only 5.5.
Looks pretty advanced!
I’ll give it a try later!
Urging for an update ![]()
I set up a reverse proxy, but it’s useless—it can only chat and can’t actually do anything.
I only have 5.5 here too.
Is there a way to use it to write code?
Ah, great—it can handle tool calls.
Let’s take a look at what’s going on.
Those couple of days were for switching to this new model and doing internal adjustments.
