Sharing some grok_token perks with everyone 【Power Outage Claude】
This is a CF static website set up using our site’s subdomain https://yooxi.loc.cc/. Inside, you’ll find redirects to different addresses, including:
  • Personal transit. Currently, only grok4.5 is supported; you’ll get bonuses for registering and daily check-ins. Please go easy on the servers—if there’s too much traffic, they might not handle it.
  • Image/video testing tools. You need to configure your own models.
  • Full AI short drama workflow. From script, to keyframes, to the finished product and voiceover—all supported. Again, you need to set up your own models.
  • Memos blog. Currently it’s run by AI, so the content might not be very polished—still optimizing. Thanks for your patience!
If you have suggestions or ideas, you’re welcome to reply to the post or message me privately (I might not have high enough level to initiate DMs for now, but I can reply if you message me :grinning_face_with_smiling_eyes:). Any feedback is appreciated; thanks for your support. And again—please go easy on the servers!
Previously, it was all about getting freebies from OpenAI. Today it’s all about Claude. Transit is now supported.
19:49
  1. Continuing with Claude,
  2. If the conversation fails, you can ask the AI to return shorter responses multiple times. There are still some bugs—I’ll try to fix them tonight when fewer people are online.
  3. If it’s still not working, just @ me directly.
21:22 Channel is down. Can’t get “spea” anymore—I’m dying here.
22:03 There are still channels left—let’s keep the Claude party going!
00:01 All down. grok4.5 is down too; only grok4.3 is left for now.
2026.07.28 18:00 grok is back online. Please don’t use any probes, don’t use probes, don’t use probes. Enjoy it while it lasts!
Awesome!
The short drama won’t open!
Thank you for sharing this public-interest initiative.
Thanks, boss, for your selfless contribution.
Claim a freebie
The backend is down… It’s fully maintained by AI now. Let me take a look.
It’s all maintained by AI now, so I don’t even dare tinker with my VPS anymore. A bit awkward :xhj005:
I’ll just make a quick appearance, then I’m done pedaling :xhj28:
:xhj007:
NodeLoc login isn’t supported—please upgrade it. :xhj10:
It’s too difficult. It takes 600 minutes. Aaaah.
Send a private message to the site administrator
I can’t even send private messages…
That bad? Click the site admin’s avatar to send a message.
Also, what’s the whitelist for registration email addresses? I can’t register—at the very least, it should indicate which email addresses are allowed.
Thanks!
Take a look.
Most mainstream ones all support qq 163 126
Was gork4.5 registered using a keygen?
It was from 10 days ago. I haven’t done anything with it lately.
That’s a pretty good idea.
