- Download Tampermonkey, add a new script and import the script, then register a Claude account. You’ll have to try different emails—some temporary email addresses can work too.
- Choose a Japan node.
- Country: Germany
- Use this tool to generate a random IBAN: http://randomiban.com/
- For payment method, select SEPA.
- For the IBAN, generate one using http://randomiban.com/
If you see a green thing appear in the bottom right corner, it means the script is working.
Note: Reverse proxies don’t last long. If you use this directly and don’t get your account banned for a long time, it’s been personally tested; mine has lasted over three hours and is still fine.
// ==UserScript==
// @name TestExample Cassia Response Mock
// @namespace local.testexample.checkout
// @version 1.1.0
// @description Change checkout_capabilities response to cassia
// @match ://claude.ai/
// @match ://.claude.ai/*
// @run-at document-start
// @grant none
// @sandbox raw
// ==/UserScript==(function () {
“use strict”;const TARGET_HOST = “claude.ai”;
const TARGET_PATH =
/^/api/organizations/[^/]+/subscription/checkout_capabilities/?$/;const MOCK_DATA = {
checkout_flow: “cassia”
};const MOCK_BODY = JSON.stringify(MOCK_DATA);
const MOCK_LENGTH =
new TextEncoder().encode(MOCK_BODY).byteLength;function getTargetUrl(input, method = “GET”) {
try {
let rawUrl;if (typeof input === "string" || input instanceof URL) { rawUrl = String(input); } else if (input && typeof input.url === "string") { rawUrl = input.url; } else { return null; } const url = new URL(rawUrl, location.href); if (String(method).toUpperCase() !== "GET") { return null; } // Allow main domain and subdomains const hostMatched = url.hostname === TARGET_HOST || url.hostname.endsWith("." + TARGET_HOST); if (!hostMatched) { return null; } if (!TARGET_PATH.test(url.pathname)) { return null; } return url; } catch (error) { console.error("[Cassia Mock] URL parsing failed:", error); return null; }}
function createMockResponse(originalResponse) {
const headers = new Headers(originalResponse.headers);headers.delete("content-length"); headers.delete("content-encoding"); headers.delete("etag"); headers.delete("content-md5"); headers.set( "content-type", "application/json; charset=utf-8" ); headers.set("content-length", String(MOCK_LENGTH)); headers.set("cache-control", "no-store"); const response = new Response(MOCK_BODY, { status: 200, statusText: "OK", headers }); // Try to preserve original response info try { Object.defineProperties(response, { url: { value: originalResponse.url, configurable: true }, redirected: { value: originalResponse.redirected, configurable: true }, type: { value: originalResponse.type, configurable: true } }); } catch (_) { // Doesn’t impact rewriting } return response;}
- Intercept Fetch
const nativeFetch = window.fetch;window.fetch = async function (input, init) {
const method =
init?.method ||
(input instanceof Request ? input.method : “GET”);const targetUrl = getTargetUrl(input, method); const originalResponse = await nativeFetch.apply(this, arguments); if (!targetUrl) { return originalResponse; } console.warn( "[Cassia Mock] Fetch response modified:", targetUrl.href, MOCK_DATA ); return createMockResponse(originalResponse);};
- Intercept XMLHttpRequest
const XhrPrototype = XMLHttpRequest.prototype;
const xhrInfo = new WeakMap();
const loggedXhrs = new WeakSet();const nativeOpen = XhrPrototype.open;
const nativeSend = XhrPrototype.send;
const nativeGetResponseHeader =
XhrPrototype.getResponseHeader;
const nativeGetAllResponseHeaders =
XhrPrototype.getAllResponseHeaders;XhrPrototype.open = function (method, url) {
let absoluteUrl;try { absoluteUrl = new URL( String(url), location.href ).href; } catch (_) { absoluteUrl = String(url); } xhrInfo.set(this, { method: String(method || "GET").toUpperCase(), url: absoluteUrl }); return nativeOpen.apply(this, arguments);};
function getMatchedXhr(xhr) {
const info = xhrInfo.get(xhr);if ( !info || xhr.readyState !== XMLHttpRequest.DONE ) { return null; } return getTargetUrl(info.url, info.method);}
function replaceXhrGetter(propertyName, replacement) {
const descriptor =
Object.getOwnPropertyDescriptor(
XhrPrototype,
propertyName
);if ( !descriptor || typeof descriptor.get !== "function" || descriptor.configurable === false ) { console.warn( `[Cassia Mock] Can’t override XHR.${propertyName}` ); return; } const nativeGetter = descriptor.get; Object.defineProperty(XhrPrototype, propertyName, { ...descriptor, get: function () { if (!getMatchedXhr(this)) { return nativeGetter.call(this); } return replacement.call(this, nativeGetter); } });}
replaceXhrGetter(
“responseText”,
function (nativeGetter) {
if (
this.responseType !== “” &&
this.responseType !== “text”
}return MOCK_BODY; });
replaceXhrGetter(
“response”,
if (this.responseType === “json”) {
return {
}if ( this.responseType === "" || this.responseType === "text" ) { return MOCK_BODY; } return nativeGetter.call(this); });
replaceXhrGetter(“status”, function () {
return 200;
});replaceXhrGetter(“statusText”, function () {
return “OK”;
});XhrPrototype.getResponseHeader = function (name) {
return nativeGetResponseHeader.apply(
this,
arguments
}switch (String(name).toLowerCase()) { case "content-type": return "application/json; charset=utf-8"; case "content-length": return String(MOCK_LENGTH); case "cache-control": return "no-store"; case "content-encoding": case "etag": case "content-md5": return null; default: return nativeGetResponseHeader.apply( this, arguments ); }};
XhrPrototype.getAllResponseHeaders = function () {
const originalHeaders =
nativeGetAllResponseHeaders.apply(this, arguments);if (!getMatchedXhr(this)) { return originalHeaders; } const headers = String(originalHeaders || "") .split(/\r?\n/) .filter(Boolean) .filter(function (line) { const name = line .split(":", 1)[0] .trim() .toLowerCase(); return ![ "content-type", "content-length", "content-encoding", "cache-control", "etag", "content-md5" ].includes(name); }); headers.push( "content-type: application/json; charset=utf-8", `content-length: ${MOCK_LENGTH}`, "cache-control: no-store" ); return headers.join("\r\n") + "\r\n";};
XhrPrototype.send = function () {
this.addEventListener(
“readystatechange”,
function () {
const targetUrl = getMatchedXhr(this);if (targetUrl && !loggedXhrs.has(this)) { loggedXhrs.add(this); console.warn( "[Cassia Mock] XHR response modified:", targetUrl.href, MOCK_DATA ); } } ); return nativeSend.apply(this, arguments);};
- Show running badge
function showStatusBadge() {
if (!document.documentElement) {
document.addEventListener(
“DOMContentLoaded”,
showStatusBadge,
{ once: true }
return;
}if (document.getElementById("cassia-mock-badge")) { return; } const badge = document.createElement("div"); badge.id = "cassia-mock-badge"; badge.textContent = "Cassia Mock ON"; Object.assign(badge.style, { position: "fixed", right: "12px", bottom: "12px", zIndex: "2147483647", padding: "7px 11px", color: "#ffffff", background: "#167c3a", borderRadius: "6px", fontSize: "12px", fontFamily: "sans-serif", boxShadow: "0 2px 8px rgba(0,0,0,.3)" }); document.documentElement.appendChild(badge);}
window.__cassiaMockInstalled = true;
console.info(
“[Cassia Mock] Script loaded:”,
location.href
);showStatusBadge();
